Just picked up my first TW. 2008 model. It did not come with the turn signals, however the wiring is intact. I would like to install smaller than factory LED lights, as they are a bit brighter and the area I want to explore on my bike is pretty brushy. Has anyone had any luck installing LED's on there ride? Any help would be greatly appreciated. Thank You.
These guys have everything you will need to do the led conversion Yamaha TW200 Parts and Performance - ProCycle
You might just wanna go with the 4 mini halogen turn signals on the pro cycle website. If you go led then I'm pretty sure you need a diode kit and a led flasher
Im sure someone will chime in that has done the led turn signal conversion
I have the TuffLites (sp?), they are near indestructible. You will need a solid state flasher to maintain the legal blink rate.
i picked up a pair of mini stalk lights from cycle pro. protected under the cyclerack, i haven't broken another one since, two years running. on sale they were $10
Put LED's on the wife's TW, pretty inexpensive to do. after I got them in I was confused as to why they all turned on and did not blink! Then I realized a digital flasher was needed, then with that installed they all blinked! I took out the dash indicator and replaced it with a small LED and it worked wonderfully. If you don't want and LED on the dash you can just take it out or play with the resistance. All in all under $50 on ebay for all the stuff.
