Then i mounted the 44's "which are 22watts a piece"on the tusk deflex handguards with a bolt through the slot were the guards mount to the bars. Also i upgraded to the heavy duty light mount. The lights are angled out to the sides a bit and i did this on purpose. The led's pick up just inside the edge of the HID's high beam pattern so i have light way to the sides for seeing into corners and for suicide deer and other critters.
The toggle on the left is for the hid and the right is for the led's.
These are the same lights dustyg has. He did a post on the night pics with his pointing in with the high beams. I will get a few pics hopefully tonight with my setup pointing to the sides a bit. These lights are great and put out alot of light everywhere. So basically you run a fused set of wires"red=positive/black negative" from your battery to the dimmer box input "i went to a toggle switch first". Then the output side of the box wire the lights into the positive and negative wires of your lights and the box has a purple wire for the high beams which i ran off of the plug for the little blue high beam indicator that i took out of the instrument panel or you can just posi-tap into the highbeam wire somewhere along the way if you want to keep your panel.
