I did my first oil change.
Previous owner added a small (1/2" by 3/4") piece of magnetized metal to the oil drain screen cup. Looks like he used an old speaker magnet metal washer/plate and cut it down then bench ground the edges smooth so as not to cut the screen. It was inside the cup (the area towards the outside of the bike).
Sucker had a fair amount of fine grit and one larger piece maybe 1/16th by 1/8th.
So two questions:
Is that normal to have so much metal?
The second question is this....
I didnt open up that upper drain screw or whatever it is that is shown in the oil change sticky to see if I had oil flow. Is there any reason to do so beyond a check? Like to bleed air??
So two questions:
