Update on the Marvin Shaw Shock.
Finally had time to work on the MSS shock project. 360 lbs of nitrogen ended up being still too soft. We bumped it up to 450 lbs and also moved the fill nipple to the side of the shock. It was on the upper beveled part, but the rear fuel tank mount interfered with attaching the shrader valve. Much better now. Make sure spacers are used both on the upper and lower mounting ends. Very important to keep the shock in the proper position without much side play. This goes for any shock in general. Talking with Tim at MSS, he said it is also possible to install a heavier spring if needed and they can all be adjusted for preload.
Was able to really put the shock through the paces on our Silver City ride last Friday. Just under 100 miles of serious off road testing. It performed flawlessly. Seems to be perfect for my weight with riding gear and the travel gear on the back of the bike. I'm very happy with the Marvin Shaw Shock conversion and believe it was the correct path to follow.
