Not at all, you just need the bike on a stand where you can drop the swingarm and rear wheel down as far as possible to give you clearance to pull the oem.A question for those more knowledgable than me. If I am going to install my new Marvin Shaw Shock, does the rear wheel need to come off? Or can I simply take the load off the suspension, pull the lower mounting pin, and then let the swing arm down far enough to remove the shock?
Has a set of spacers been settled for this?
I just realized I may have misinterpreted the post. Was the lower shock eye moving around on the bolt? Or was the lower shock bolt moving around in the mounting bracket holes?I posted this in another thread, but think it is good to also post here on the MMS thread.
The rear suspension was feeling a bit loose and shakey the last couple of rides. There was a lot of play at the trailing arm shock brackets. It still had just the oem shock pin. Am using a custom Marvin Shaw Shock. My cousin and I made a couple of custom sleeves so I could use the same as the upper shock mount. Aligned them up and welded onto the swingarm brackets. absolutely no play now. Feels like a completely different bike now. Would most likely work with a Cogent shock also. ( one thing we did find out is that the upper bolt that came with the bike is one tenth of a mm smaller diameter than a replacement oem one. Wonder what the tolerance is on their bolts?
I would highly recommend one put a bolt in with correct spacers that make snug fit when installing new using the existing swing arm bracket holes if they accept a bolt that is tight. Must match the diameter of the lower shock hole or make an aluminum tube bushing for the shock hole or the swing arm holes.
Definitely an appropriate response to the bracket holes ovaling out.The left and right swingarm bracket holes were getting worn and became oval. The shock hole is fine and I had the aluminum spacers in. I made the mistake of just using the pin instead of putting a bolt and nut on. This one is torqued to 40 ft lbs just like the upper bolt. These custom made welded steel spacers eliminate the need for any other spacers. Less parts=less movement. We bored the spacers to just a hair over the diameter of the bolt. No more play.
I can see why it is extremely important to make sure the rear shock system is tight and has no play at the mounting points.
