There's a bit of climbing involved to reach the catwalk so....probably not.
Every time I go past this bridge I can hear it calling me...I don't know if this catwalk goes all the way to the other side because there is a bit of an arch to the structure...but it sure would be neat to check it out.
Always had a thing about bridges...and railroads...and caves/tunnels...
In the bridge photo...there is a column that has some purple graffiti painted on it. The column directly opposite, has a ladder that runs all the way up to the bridge deck, although it is blocked off near the top...I guess someone must have tried climbing up/down and hurt themselves...the purple-painted column has no ladder.
204231
it doesn't look like the catwalk goes into the center span. plus they would most likely throw you in jail as a terrorist who was going to blow up the bridge, if they caught you out there
If you look closely (or if you can enlarge the picture on your own PC) it looks as though the catwalk goes up the middle of the arch. When we were on the other side, I noticed the same thing.
I could be wrong...but there's only one way to find out.
