1 - 20 of 74 Posts
I've learned that I like working on my TW almost as much as riding it. I've only had it 8 months and feel like I'm maxing out on the mods (probably not but that's what this post is for).
So far I have done: IMS Super Stock footpegs, JNS Headlight, Tusk Utility Rack, Tusk D-Flex handguards (basically copied Rocky Mountain youtube vid for that list).
Looking to do: Shinko 241 front tire, skid plate
What else? What's your favorite mod you've done, and what else are you looking to do?
Is the Tusk Utility Rack is hard to install ?
Could you please post a pic of your tbub ?
I did not think it was very hard. I did have to drill two holes in the fender but the directions were clear and easy. Mainly bolts onto the fender, and the existing bolts for your passenger foot-pegs. Took me about 2 beers to install. I love it. It's very sturdy.
Let me try to post a couple of pics.
maxing out on mods already?
Ah, watch and learn, Grasshopper ...
in my sig i have the best 25 mods i've done...
The 25 Steps to My Bike or The Evolution of My Bike but wait there's more!
i doubt it will ever be completely done. have fun, make it yours and enjoy riding it.
ride on!
Here is what I am considering;
1) Fuel filter - a must have. Cheap insurance to prevent fuelling issues.
2) Skidplate - still not sure if I need one yet.
3) Hand guards - protects your hands and bike controls
4) New grips - the stock grips are not so good
5) Shinko 244 or 241 - I found out why they call the stock tire a "Death Wing"
6) High mounted fender - for looks and to prevent mud buildup between tire and stock fender
7) Larger foot pegs - I have size 12 feet and the stock pegs are small and awkward
8) Longer shifter - Not sure if I need one yet. I am hoping the larger foot pegs will make shifting easier.
9) Adjustable clutch and brake levers - Should make life easier and more precise
10) Jet Kit - get that carb running to its full potential
11) FMF Exhaust - Not sure about this one. I'd have to hear a good comparison between stock and the slip-on. I
definitely do not want to be "that guy" who wakes everyone up when I go for an early morning ride.
My favorite so far is the cycleracks.com rear rack. No, the ammo box on top. No, the wolfman saddlebags that fit perfectly under the cycleracks. No, the Jimbo shield. No, the Mad Dog seat cover. No, the aftermarket cyclegear hand guards. No, the aftermarket cyclegear big boy foot pegs. No, the.... you know what, I like everything i've done so far and dammitt, I fear I'll never be done. Shinko tires, pro taper bars with Rox risers, pillow top grips with heat, Endustrian heat shield, the.... see what I mean. Not to mention all the accessories for the rider. UUGH!
ride on!
I'll definitely check this out. Thanks and this is what I'm looking for...more ideas.
Discussion Starter #10
11) FMF Exhaust - Not sure about this one. I'd have to hear a good comparison between stock and the slip-on. I definitely do not want to be "that guy"
Hadn't thought of fuel filter
Skidplate is on my list
Love my handguards...true story, laid my bike down for the first time (in mud thankfully) the day after installing hand-guards. Probably would have damaged clutch lever without them
Grips - didn't think of these until I probably over cut them due to installing hand-guards
High fender intrigues me
Love the larger foot pegs
Have thought about exhaust also
Discussion Starter #11
You're right..haven't even started with rider accessories. I already have two helmets and want a third. Rider boots, better riding clothing, better winter riding gloves (I like my summer ones).
i have size 11 and definitely needed a longer shifter, it made a huge difference in finding it, in spite of not looking like much more.
Here's my mod list to date;
$0 Chopped 1" off each handlebar end for a narrower profile and better riding stance.
$30 kick stand - XT225 installed
$120 tank - XT225 lined and instaled
petcock - XT225
fuel cap - mod to remove key lock
$12 tail light assy - replaced with LED
$11 front fender and bracket - removed and installed tall fender
$89 skid plate - removed and installed Richochet
$11 clutch springs -removed and replaced w/stronger springs
$67 chain - removed and replaced with DID x-ring
$5 rear turn signals - removed and replaced with LED off eBay
$5 front turn signals - removed and replaced iwth LED off eBay
forks reflectors - removed
$20 seat cover/pad - installed camo
$65 bar risers - installed
$32 pilot screw adjuster
$6 pilot screw
$53 front tire
$25 foot pegs
$39 tire sealant
$14 pilot jet from 31 to 34
$72 LED headlight
$10 carb needle shims installed
$5 Quick release seat bolts/pins
$55 Jimbo Shield
$27 Folding, longer shift lever
$25 service manual
$12 longer rear brake arm (for better braking power w/ the leverage)
$11 LED flasher relay
$10 LED dash lights
$3 tank decal
$45 Givi trunk mounting plate
$11 oil filters
$8 Irridium spark plug
$100 Manrack rear rack
$212 Kick start kit
$40 Bark busters
$95 LIFo Battery
$10 Pro Taper Grips
$25 Kimpex Grip Heaters
$14 Fork Seal Guards
$10 Tach/hour meter
$50 Stainless pipe
$40 gun scabbard
$10 folding brake peddle
$30 battery charger
$130 Doubletake indestructable mirrors
$50 shorty clutch and front brake levers
$60 camo vinyl covering
I don't have all the mods installed in this photo, like the camo seat cover, but you get the idea....
Discussion Starter #17
petcock - XT225
$6 pilot screw
$53 front tire
$25 foot pegs
$39 tire sealant
$72 LED headlight
$55 Jimbo Shield
$25 service manual
$10 LED dash lights
$3 tank decal
$11 oil filters
$212 Kick start kit
$40 Bark busters
$95 LIFo Battery
$10 Pro Taper Grips
$10 Tach/hour meter
$50 Stainless pipe
$40 gun scabbard
$30 battery charger
That's it?
J/K
Well at least we know you keep good records. Sweet TW BTW.
Done:
Raised front fender with SS washers
Ricochet skid plate. Coated top with bedliner and painted silver
EBC HD clutch springs
Gold (!) DID X-ring chain
fork reflectors - reversed
Rox pivoting bar risers
valve core removal valve stem caps
Krator foot pegs
Ride-On tire sealant/balancer
Smoke color Jimbo shield
IMS shift lever
Manracks rear rack (Utility)
Rotopax mount and 2 gallon can
Manracks front rack
Rok straps
Sebastian's kick start kit
Barkbusters with White jet handshields
Battery tender
Ken Sean folding mirrors
Spot Satellite holder
Ram Toughclaw with X grip cell phone holder
USB ports voltage indicator
To do:
Rejet carb - have parts
fork preload adjusters and add fork oil - have parts
fork emulators (maybe)
tankbag mosko moto?
pillow top grips
grip heaters
water crossing carb vent mod
Beeline Moto (when it comes)
new bars (when I bend these)
LED lighting
tool roll
luggage Mosko moto?
Lithium Battery (maybe)
modify brake lever with step
I have added a re-donku-las number of accessories similar to the above Gents. The 3 favorites that jump out to me are:
The 2" Rox handle bar risers, the heavy duty fork springs and the hugest set of footpegs I could find (pic attached), they required some modification, but are super comfortable for standing long time GI. :)
These bikes are addicting.
1 - 20 of 74 Posts
