1 - 20 of 22 Posts
Thanks to this site and cool people for all the great info. This was a fun build. I think I will be having alot of fun with this mini adventure bike. Picked up March 19th when I saw an instagram video from a powersports dealer about an hour away. Paid $6442 otd here in so cal. I walked out of a dealer couple weeks prior quoting me $7100. It definitely hurt, but watcha gonna do?!
Here is my build info and things I ran into:
1. Shinko 241 - Tire ironed on perfectly fine with windex. I found that two roundish spoons to work the best.
2. Ricochet skid plate in black anodized - very cool
3. DMO Specialties footpegs - Feel and look like quality and bolt right on
4. ProCycle rear shock spring 19kg - easy to remove and replace- Its blue, very cool. Had a local shop switch out, they charged $40. I'm 235 + gear, I needed it
5. ProCycle front fork springs 70kg - easy to do - 35mm 10 w oil with the oil measure thingy - Feels like a different bike. I'm scooting around the trails more like a dirt bike now.
6. DG V2 slip on exhaust - Its loud! Procycle has three different type of decibel reducers. I have one coming to turn down a notch. We will see.
7. Dryspec heat shield - nice looking - stays cool, although the DG pipe doesn't seem to get extremely hot. I installed some sticky back heat shield to the back of the plastic as well, just to be safe.
8. Purchased a sigma 6 stage 2, but only did the idle screw mod at 2 1/2 turns, 2 shims, 130 main, and I believe a 35 pilot. At full throttle there is a miss, so I have ordered a 128 main, 34 pilot, and will play with things from there. Definitely woke the bike up drastically!
9. K&N filter, but I will change that out to a Uni when they are back in stock most likely. I plan on riding dusty trails.
10. Moose foldable shift lever
11. ProCycle high mount fender bracket
12. Maier carbon fiber plastics - I like them
13. Clarke tank - as you all know, the right side hole is off by 3/4". I tried to modify an offset mount and drilled a hole in that lower bung. Gas pouring all over the place! yes, I drilled a hole right into the tank. Heated up and patched with solder gun, but have a new tank on the way to be safe. (Only reason I haven't volunteered to drop bike at IMS, embarrassed of it) Another note: 2" Rox anti-vibe risers hit the tank just a bit. I may grind them down a bit. I installed a couple sticky rubber bumpers on the tank as a stop for cushion, I can live with it.
14. 2" Rox anti-vibration risers - very cool- These worked with KX high protaper bars by relocating the brake line to left side. Undo one screw bottom left of headlight bracket to pull over. Also gained a little more slack in brake line at the bracket mount on the fork tube. Clutch cable was fine!
15. KX high Pro taper Contour 1 1/8" bars - most likely maximum height you can go with 2" risers
16. Highway dirt bike handguards with mirror kit - I like them and mirrors work great. Doubt I will ever break a handle, super heavy duty.
17. Seat concepts tall foam kit - Not hard to do - Home depot and Lowes sell stainless T-50 staples, about 4x the price - No opinions yet since haven't broken in
18. ProCycle tail tidy kit
19. Cyclops led blinkers - I really like these, have them on another bike. Running lights on front and work with break light on rear, very bright. Have stood up to crashes. Tip: Just a diode did not work for me, to keep the indicator blinker flashing. It didn't work with the old indicator bulbs or all new led indicator bulbs. I removed the diode that I installed and switched the flasher relay to an led, works like a charm. All indicator bulbs changed to LED. I prefer to see when my blinker is on.
20. JNS DOT headlight -
21. Man Rack with Rotopax mount integrated - Looks great. Very nice, perfect for me.
22. Nelson Rigg RG-020 saddle bags - fit the bike great for carrying a ton of stuff on a day ride, but if I'm going moto camping I will throw the Tusk Highland set on, which also fits nicely
23. Garmin 700i with Inreach - TIME TO GO GET LOST
that's a lot of mods. My favorite one is the Garmin, because I could really use one of those. Now that your bike is all set, its time to go on adventures and share stories of those :)
Fantastic looking Tdub!.....one that is purposefully built, well done!
204 TW200, Jets 'n Shims, DGV2, Acerbis Guards, ProTaper KX, JNS LED BLK
Love it! Christmas in Spring, eh? Nice job.
Tell us about the tank graphic. Design eye on the ‘Dub guy. Awesome look.
Reactions: admiral
Discussion Starter · #10 ·
Thanks guys! mapping a route now for some trails in the Bishop area in less than two weeks. Staging at a motel in Independence Ca. for the weekend. Seadub, I used my Cricket machine for the decal. Ordered cheap carbon fiber vinyl from Amazon, fun stuff!
Crazy timing, I am just finishing my build too.
And almost a carbon copy build!
Pics coming next week. (Waiting on my tall seat concepts)
Nice job!
Another nice build write up coming soon!
214497
I have had terrible luck w after market jet kits.
With mine I went with a 128 main, a 34 pilot and I shimmed the needle .031 in. Using Polaris plastic shims, (local dealer recommended)
Fuel screw two turns out.
Runs and drives PERFECT!
What altitude do you ride at?
Sent from the demons in my head
'08 TW200 with all the usual add-ons. '06 TW200 Beater in need of TLC
18. ProCycle tail tidy kit View attachment 214464
That is a great looking build, though I should hope so with all the dough in farkles and mods.
I think you may have convinced me to get the Meier carbon black plastics for my T-Dub project bike.
Farnorth, I will give that a shot, Thank You!
You know, I figured the bike would run better..
But damn it’s amazing how good that little motor will run when jetted proper.
Not sure I would do the Polaris shims because they were too lg diameter to fit in the diaphragm cup and took a lot of trimming.
But .030” of shim worked great.
My bike is 99% LED the only non LED is the blinker indicator I could not get that one to blink w LED
Any suggestions?
Everything blinks perfect ( I have resistors soldered in ) wouldn’t blink w stock or a LED flasher unit.
Discussion Starter · #18 ·
Any suggestions?
Have you tried changing it to an led bulb?
Discussion Starter · #20 ·
1 - 20 of 22 Posts
