1 - 20 of 30 Posts
I recently acquired my 1995 TW with 16,000 miles (still can't believe it) and I wanted to make it mine and make it stand out from the crowd. I had a little time left in the season to ride it before I put it in my shop to "restore" it.
This is what I started with, orange seat and all. I wasted no time in riding it ~170 miles to my cabin without any drama. The thing runs great.
I quickly ordered a new seat cover, and a coleman pad.
I continued with the modifications. Higher bars, handguards, and a luggage system were next.
Then, being located in Western New York, the cold weather came. This was my sign to start tearing down. I wanted to clean, restore, and change the appearance of nearly every part on the bike (RIP rainbow warrior). I had a few different ideas on what color scheme to go with, but settled on an army-like olive green and black. I used several resources such as yankee preppers videos on youtube and that one "Zombie-Stomper" build.
I started with the wheels. Like yankee prepper had done, I used rustoleum truck bed coating. Index cards are helpful in masking off the tires.
Next, the forks. I do not want a single part of the bike to be silver, only the green plastics and everything else needs to be black. Here I used the truck bed coating for the lower portion and plastidip for the boots.
The bike is currently being torn down to bare frame in order to paint it BLACK. I plan to check the valve lash, timing chain adjustment, and go through the motor for my own peace of mind, even though it runs like a dream. Both case covers have bad leaks and I have both new gaskets to replace them. I'm looking forward to cured paint on the frame so I can start putting it all back together. Updates to come.
(continued) I proceeded to remove, clean, and paint all of the plastics on the bike. Anything that was blue would now be olive drab.
The paint I used was rustoleum ultra flat camo green, I'm really loyal to rustoleum and I think they have the best spray paints. This paint will bond to plastic and covers extremely well. It even filled some cracks in the front fairing.
The tank was stripped down to bare metal with rustoleum aircraft stripper and some heavy grit sandpaper. I applied about 3 coats of rustoleum filler primer to the bare metal.
The final result is a very even, flat paint surface. Since the color is flat there is not much sanding or surface prep necessary. I'm really loving the color so far.
Great start!
I look forward to seeing progress pictures.
Started to paint the frame, the color is Rustoleum "hammered" black. I didn't expect the almost gunmetal color, but I think I'm okay with it.
I also used Rustoleum high heat paint to cover the exhaust and head pipe which were rusty and ugly. The result is a clean looking flat surface. This paint is meant for rusty grills and the like so it worked very well. Resistant to heat up to 1200 degrees.
All I need to do now is paint the swing arm, and both valve covers and the cylinder head. Then I'm on to reassembly!!!
I used this on the header pipe as well. Didn't last. I had wire brushed all the rust off and it still didn't stay on after a couple rides. Next thing I'm gonna try to cover up the header rust is black exhaust wrap.
This paint did last and work well on the muffler and I was very pleased with that, so repainted wasn't a complete waste of time & effort.
Frame and gas tank look good!:icon_thumright:
Read Only
Did you have to rebalance the wheels/tires, or was it not thick enough to have to worry about that?
Discussion Starter · #11 ·
I was thinking about wrapping the head pipe already so maybe I'll do that before I even ride it. Thanks for the insight!
Discussion Starter · #12 ·
The olive drab is really eye-catching for me. Do you plan to use a flat clear over the tank, to protect it from fuel?
hmmm... I had not thought of that. I may just try to be very careful and leave it as is. The tank is not very hard to get off the bike if i need to touch it up.
Discussion Starter · #14 ·
Quick update, I've finally finished all of the restoration parts of the build, and it's time to start reconstructing the bike. I finished some of the final parts tonight:
I painted both triple clamps with the same paint used on the case covers and cylinder head. Not necessary to use heatproof paint here but I was just using what I had.
Swing arm got more of the truck bed liner.
I replaced both case cover gaskets, painted the case covers themselves with engine component paint in glossy black and the cylinder head. I purchased an Allen head bolt set off eBay for both the reason that it will make it easier to service in the future and also that I striped out two or three of the originals. The crank case remains the original factory grey. Once all of the other components are on there it won't be noticeable.
I could not resist putting the newly painted fender, tank, and the seat on the frame to see what it looked like. I like.
Your project keeps looking better and better. I thought I could live with a silver swing arm and silver triple clams; maybe not after seeing your project.
Discussion Starter · #16 ·
Looks great! I can't wait to see your completed OD TW. Here' is my 1992 in desert sand:
Bike looks awesome! Desert sand was one of the colors I was thinking about doing. I love the military look. Did you do a complete teardown? How did you paint the frame?
Thanks! My bike had been partially restored when I purchased it. The frame, exhaust, and swing arm had already been re-painted (black frame, silver swing arm)
All I did was remove all the body work and paint desert sand. I almost went with OD green, so I am eagerly awaiting for you project to be completed!
Discussion Starter · #18 ·
Thanks I look forward to it too! One more question: when you painted the plastics and tank did you put a clear coat or any type of coating over the gas tank? Or are you juts very careful when you gas up?
I cleaned all the body work and tank in HOT, almost scalding water with dawn dish soap - scrubbed vigorously.
After they dried, I re-cleaned all body work and tank with non-chlorinated brake cleaner.
No primer, no top coat, just really clean bodywork and desert sand spray paint that bonds to plastic well. The clean, ruffed up body work yielded a good bond, even when the plastic is flexed.
Yes - very careful when filling with fuel. Eventually I'd like to upgrade to the large, plastic fuel tank, so I'm not to worried about fuel spill / occasional touch up.
I even painted the seat with the special sand color automotive vinyl spray paint which work amazing well - my seat cover was brand new - BLUE!
My paint job was approx. $30 and 1 hr labor.
Simple and cheap - just like a TW200!
Discussion Starter · #20 ·
The bike came back together much faster than it was taken apart, actually. Tonight I put the swing arm on, finished up the wiring, and put the newly bed lined wheels and tires back onto it. Next is just a few odds and ends like an o-ring chain and inline fuel filter. Once again, I could not resist mocking the bike up with the tank and plastics.
I'm so happy with how it came out. Updates to come as I work toward a running complete bike!
1 - 20 of 30 Posts
