I don't know why everyone wants a 350 TW! I haven't noticed a performance increase at all
Kidding aside, swapping in an XT350 tank is a very easy and worthwhile modification to extend the range of the TW.
I've had the tank for awhile, but haven't had the time/need to get it installed until now. I pretty much followed Peruano's instructions here for mounting it, although I came up with my own rear mount. I shoved the tank all the way forward on the front mounts. For some reason, even when moving the tank back the rear mount on the tank wasn't parallel with the original mount. So, I bent the flat bar up slightly to match the angle of the tank mount, then cut and welded a short section of square tube underneath to support it. Sorry for the blurry pictures.
The threaded stub for the mount was bolted in place just like Peruano recommended, which keeps it simple and easy.
To allow the seat to match the steeper angle of the XT350 tank I cut the seat base with a pair of tin snips. It cut very easily. I then used my 4" grinder to clearance the ribs that were interfering with the rear tank mount, preventing the seat from moving far enough forward to get the bolts in. Mods to the seat were minimal.
Thanks to Peruano, Mr. Gizmow, lizrdbrth, Ronnydog, and the others who've shared their knowledge and experience about this modification. My first trip out since the addition of the XT350 tank I almost ran it dry by riding 193.9 miles. Totally worth the time and effort. By the way, Peruano suggested checking out the XT350 thread on advrider.com as a source of used tanks. I think that is good advice.
