1 - 4 of 4 Posts
So when I lived at sea level, I had the standard 2.5 turns from base. While on Yellowstone (6000+ ft) it kind ran with low power issues through the park, even though the ride around west Yellowstone seemed fine. Now in the black hills (4000+ ft), it still has a rough time starting.
Even with choke all the way out, it seems to struggle and does not 'race' like at did level.
So at this altitude should I lean it out more by turning the screw in....say 1 turn?
Less oxygen at higher elevations requires less fuel be mixed in. So yes turn it in a full turn and test its performance. I am NOT a mechanic so I verified this advice via a carb jetting article:D
Tom
You probably are more rich than you need to be for starting. Don't use the choke a much as you think you need. The pilot has little effect on running down the road, only at idle, start and taking off.
Nunya, we could help you out better with more info. What carb is it, new or old style? What jets are in it, stock or other?
1 - 4 of 4 Posts
