1 - 13 of 13 Posts
I installed some surplus MSR ATV Low handlebars on my TW I bought for my V Strom. They are about 1" taller than stock, and about 1.5-2" wider than stock. They were less than $30. I also added some 2" aluminum risers I found on E-bay for $19.00. As someone who likes to stand on the pegs while riding-this works great for me and I was able to use the stock cables. 20160422_185437_resized.jpg
I used the ATV High bars from here, new grips from Amazon.
http://www.walmart.com/search/?query= msr atv high bar&cat_id=91083
I pulled the headlight assembly, and ran the cables behind the triple tree to get more slack, pretty easy, and I have enough slack to add a riser if I want more height.
ATV HIGH 785 180 87
BENDS
WIDTH
HEIGHT
PULLBACK
HIGH 800 91 63 \\ MID 810 81 60 \\ LOW 810 68 67 \\ HIGH 810 101 80 \\ LOW 805 72 62 KTM HIGH 795 120 87 RM HIGH 800 81 77 RM LOW 816 74 55 YZ HIGH 815 84 76 MINI HIGH 730 118 62 MINI LOW 735 91 65 ATV HIGH 785 180 87 ATV LOW 780 100 78
Found something very cool for figuring out riding geometry. ..Motorcycle Ergonomics
Looks like I want to go 3" up and 3" forward (which is probably about the distance I moved my stocks forward) on the bars and 2" forward on the pegs....which is about what I visualized as comfortable but very cool to see what changes do to the ergonomics
Now to find someone to make me new footpeg brackets that relocate as well as accept yz footpegs...and also would need to extend brake and shift levers...for a riser for handlebars has anyone tried rox anti vibration risers?
No, but I've had the Rox Pivoting risers since just a couple of weeks after purchase....I got 2" higher and 2" forward, kept the stock bars, and have never seen any reason to change them since. I'm 6' with longish legs and arms (32 inseam and 35 sleeve). But I don't stand up a whole lot, being old.....:p YMMV
I just installed tag 1 1/8 bars with pro taper risers,about 1-2 inches higher,wider than stock, feels great,cost about 65$,using stock cables.
That is exactly what I am going for..Did you get the EVO or Contours? Did the riser convert from the stock 7/8 to 1 1/8 ?
Does anyone have a suggestion for replacement bars. Would like to have something higher and possibly a little wider, but with out replacing cables or wiring. Brand or part # ?.
Thanks Big T.
I have a 2006 and installed 2" Roc risers and the cables were fine with the higher bars. What part of PA are you from?
1 - 13 of 13 Posts
