I just purchased a new 2023 TW200 from a dealer. It had under 1 mile on it when I picked it up. I trailered it home which is about an hour from the dealer. When I got home and tried to ride it, I noticed that shifting was a real pain. I had to at times push the clutch forward with my hand. It was also more of an on or off than a gradual transfer of power making the bike lunge forward and at times die. There was also quite a bit of a burning clutch smell going on and quite a bit of clutch slipping while driving without using the clutch. For instance, going down the road in 4th or 5th gear the engine would rev up and felt like I was pulling on the clutch a slight bit slipping it while driving down the road. I didn’t know if it was just new bike smell, but I get the feeling it was the clutch.
After a bit of riding and quite a bit of fiddling, I decided this just couldn’t be right. I had tried to adjust the clutch freeplay but something about the way the clutch lever was just hanging around didn’t seem right. I followed the clutch cable to the lever on top of the engine case and the spring did not look right to me. I didn’t know what it was suposed to look like but when pulling the clutch lever, the lever on the engine and the spring didn’t seem to function right.
So, I got on YouTube and tried to find video of the lever on the engine case working and I noticed in one video that the spring was not installed right. I fixed it and it worked so much better. I thought I had solved all my issues.
The next day, I started the bike up. It was in neutral warming up and when it was time to ride away, I flipped up the kick stand, pulled in the clutch and shifted into first gear. The bike lunged forward and died. It was if the clutch was not pulled in. I tried several more times and repeatedly the bike lunged froward and died. After the sixth attempt or so the bike lunged forward but not as hard and it did not die.
I drove it to the dealer’s sister store in my town to have them look at it. They are owned by the same company, but they are a Honda and Kawasaki dealer. They said they would take a look at it the following day because it was not showing the problem after driving it to them.
They did see the problem the next day although not to the extent I was describing. They said they took off the cover and looked at the clutch internals and everything seemed fine. The bike still lunges forward a bit at first, but they said once everything is all warmed up it goes away. That is how they are leaving it at this point.
I get the feeling that driving it around that first day messed up something with the clutch. Does this seem like normal behavior for the TW200? Does the TW200 need the clutch warmed up or else it does not fully disengage when the clutch is pulled in, it lunges forward? Seems unsafe and I feel like something got messed up and they don’t want to deal with it, but I don’t have a reference.
I did find a video on YouTube showing the exact spring issue I was having if anyone is interested. New TW200?!? TW200 Clutch Spring Mistake #shorts
Can anyone with a new TW200 tell me if this behavior is normal? I would like to force them to fix it if it is not normal, but I need to know if that is the case.
