1 - 16 of 16 Posts
Hello to all.
Daniel aka Brokennose (old gamer handle)
I'm a newby entering into the bike scene. Decided on a dual sport for my first. This way I'll have a utility/trail bike that I'll still like and use after I upgrade to a real street bike.
The more I look around the more I'm being pulled to the TW200. Absolutely love that its barely changed through out its existence. Love that its still carbureted and the ease of maintenance.
My plan now is A. locate a TW200.... buying new isnt off the table but seems an awful waste.
Service manual.... Ive got a few old IH Scouts (66 800, 1980 Scout II)and if I've learned nothing else, its that the service manual is the bible that answers all questions, and puts you on the right path.
Couple mechanical upgrades in mind, but that's all depending on what I end up with.
Any tips for a prospective buyer and new owner?
I'll update when I bring one home. Thanks for providing the info and knowledge base to tap from.
Daniel
Welcome from Maryland. Please update your profile with city and state and we can possibly help you find a used bike.
Welcome to the forum!
The pricing and availability of used TW's vary greatly depending upon the location. There are really no bad model years that you need to avoid. 1987's were the first model year and have an electrical system that is unique to that single year. Years 1988 -2000 are virtually identical with the exception of colors and graphics. Beginning with year 2001, Yamaha took away the kickstarter and replaced the front drum brake with a disc brake.
The service manual and supplements are available for downloading here:
http://tw200forum.com/forum/technical-write-ups/70-service-repair-manuals.html
Any questions, just ask. We are always happy to provide misinformation and bad advice ;).
Brian
I personally would buy 2010 and above. there was improvements to the head base gasket. I have a 2006 and mine leaks. Depending on your skills Kick starters may be less expensive to install.
Hello to all.
I'm a newby entering into the bike scene. .....
Boy, I l dunno, you might want to think of another handle! But then, you know what actors say to each other just before going on stage: "Break a leg."
Actually, the TW200 service manual leaves a bit to be desired in some areas.....but THIS FORUM doesn't! :D
Brokennose I was in the exact same boat as you a year or so ago. The TW's a damn near perfect choice. Inexpensive, easy to maintain, easy to work on, easy to modify, and not fast enough to get you into too much trouble on the street. Buy used and be patient, good deals pop up from time to time. There's a Classifieds section on the forum I'd check reguarly, some real gems from trusted forum members pop up over there as well.
As far as kickstarters go, there's a forum member who's been working on putting together an aftermarket kickstart kit together for our bikes for relatively cheap. Search "Zongshen kickstarter kit" it should pop up. May be an option to pursue if you find a good deal on a newer bike.
Best of luck, searching for the right bike's half the fun!
Discussion Starter #10
Lol I know... after years an years the logins and passwords become overwhelming. These type of forums all get the same so I dont have to remember more.
Welcome aboard, Brokennose!
Welcome aboard, Tcruarceri!
Dude! What happened to your schnozz?
Welcome aboard Brokennose. We have broken a few noses here and got a few out of joint but this mostly goes on in the section titled "Off Topic" we often refer to as the Basement because it is below the main forum section.
Find a nice TW and the model year is not all that important. Prior to 2001 and it will have both kick and electric start. They can all have a kicker installed but the kits are getting very hard to find since Yamaha discontinued them. Any blown TW engine that has the kicker can be scavenged for it and it will fit any years TW. In 2017 the TW will be 30 years old and with very little real changes over the years. Take a rainy day and sit and read some of the many different threads and you will get the idea. We are always here to help and no questions go unanswered for very long. Pictures of prospective bike purchases will greatly help us to guide you in your search. Any bike older than 6-8 years with original tires and chain/sprockets will likely need those replaced so use that as a guide with pricing.
1 - 16 of 16 Posts
