1 - 9 of 9 Posts
I went a little overboard... But I had planned on doing two before I decided on just one.
7" 55w- HighBeam turns it off (but may end up running the second one if I decide to make another mount)
More info on the light please.
Where did you get it?
How did you mount it?
I want to switch to a large round light.
Thanks!
Headlights from amazon
http://www.amazon.com/gp/product/B009RB9W9I/ref=oh_details_o01_s00_i00
Brackets from The Pot
http://www.homedepot.com/h_d1/N-5yc1v/R-202033899/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=4+in.+corner+brace&storeId=10051#.UM6hgG_AeSo
I used .25in. nuts,bolts,washers & lock washers. I bolted to the original light bracket. The brackets over lapped. I drilled the mounting hole.
I had to use 1.25in. bolts to mount the brackets as the 2 4in. brackets arent wide enough to bolt on the outside of the original frame. So I bolted them in the inside allowing me to overlap and drill a hole to run the bolt through that the light uses to mount.
Wiring was straight forward. I am only using the low-beam wires. When starting, I flip to high to reduce the battery draw.
Excellent!
Thanks mate
1 - 9 of 9 Posts
