Welcome!
Really looking forward to seeing some pics as you share them.
Layne, case will ship to your Dad's on Monday as United Parcel Service is working Presidents Day. Hope it will meet your needs, it seems pretty sturdy. I replaced the lock and provided an extra set of keys and some graphite lube to (I hope) keep it working smoothly. Take care and post often. Gerry
Layne, In my opinion, the Haliburton case would not serve you well as a 'side-case'. Tom has his mounted on top of his rear rack, perhaps he will post another picture for you. If you want TALLER, since I am a man of many cases, I can do that as well:
This is a stout polypropylene case used for a Ryobe battery tool-set. I have it 'hollowed' out and ready to go. It is not as fancy as the Haliburton, and to lock you will need to wrap a lock/chain around the handle so it can not be opened (clamshell design). This has a slightly smaller 'footprint' but is much taller. I will hold off a day to here from you as I will need to find a shipping box. Gerry
Layne, While photos of my bike's aluminum case are elsewhere, I'll post one here for convenience. I like it because the junction between lid and case are ideally waterproof/dustproof etc. Its merely attached with 4 U bolts with holes drilled through the case, but I did pad between the case and the luggage rack to reduce wear and vibration. Its mounted on the standard oem luggage rack which is admittedly not as robust as the after market Cyclerack that so many folks have chosen; hence when I built my secondary braces pictured below I attached to the pax footpegs site and the main frame and not to the more flimsy frame extension and or turnsignal mount that are used by the oem luggage rack.
I've also built some simplistic braces to hold my saddlebags out from the bike using the passenger footpeg attachment point and the furthest back point of the main frame as the second brace attachment point. Its hardly elegant but it has performed well even when I've loaded my saddlebags with rocks and other heavy cargo.
The locked case is convenient when I leave the bike during hikes. I've considered adding some extra attachment points so the cargo net would be easier to attach when I wanted to pile something on top of it. There are many options and I'm sure you will be able to better than I did with my primitive metal mending strategies and welding resources. Tom
