1 - 13 of 13 Posts
Hi everyone, I bought my 2020 TW last week and an getting closer to the recommended break in miles.
I am riding almost exclusively on secondary back roads, 30-45 MPH, I do hit some 55 MPH one's in the current ride area.
I am at about 780' above SL, been damn hot and humid, mid 90's 98% humidity.
Should I stick with the stock jet and air mixture setting for this elevation and type of riding?
Running 18lb F&R cold, non-ethanol 87 gas.
I would like a little more top end without the high rpm's, so I was looking for suggestions on sprockets also.
This bike will NEVER be on the Interstate.
Mods done so far.
I have added the oil cooler, cleaned out the screen where the filter goes, also drained out the crankcase and get a little metal out as expected.
USB charger port.
Brake light flasher, LED brake light.
Blue LED Speedo light.
Brush guards.
Nicely done so far bro. I'd say all you need to do is open up the air fuel mixture screw to about two and a half turns out from gently seated and then fine tune it from there. You could put a 15 tooth sprocket on the front or 47 tooth sprocket on the rear and I think you'll be good to go.
Sweet, I'll look at getting to that screw tomorrow, I have a sprocket in cart for checkout.
I want to get a Jimbo screen, a LED headlight and a rear rack when I can finally decide on one.
Also, what's the typical lifespan of the factory chain?
OEM chain is pure junk....get rid of it ASAP.
Get a QUALITY o-ring or x-ring chain....keep it clean and lubed and it should last 10,000.
I would hold off on re-jetting for now; get to learn the bike and if you still think you want (fractionally) more HP out of it in a couple of months, then re-jet.
Use quality synthetic oil....keep your air filter clean and freshly oiled...install a fuel filter...check your chain and sprockets weekly...use only ethanol-free gas and it should last until at least 30,000 miles before needing anything major.
Jimbo Shields are cool, you'll like it. Before you get too many more miles on it, I would invest in a O-ring or X-Ring chain and put it on along with the new sprocket.
Reactions: grewen
As TW in BC suggests don't rejet it, in fact you may not need it to re-jet it at all given how you stated you use it and at what altitude.
i guess i am the lone wolf once again. one of the first things i did to my 2020 was to rejet, it starts without the choke and runs great, it did gain some power, but only because it is now not starving. 1 up on the pilot and main jets and 1 washer under the needle, turn the idle screw out 1 3/4 turns. $23 from yamaha, no fancy kits costing $80. i would think at your altitude this would be ideal. i also ride like you described and found the 15 tooth front sprocket change to be great, still lots of low end and it is happier at 55-60
Alright, got the plug out, air screw was 1.75 turns out, in, then out 2.5.
Going for a ride this eve to test and adjust as needed.
The 2½ turns is a starting point. You may find that it runs better at 2...or less.
I set mine to 2½ but then cranked it in to about 1¾ where it runs best. Maybe as the weather cools over Autumn, I might have to crank it back out to 2 again....it is a DYNAMIC setting.
Mods done so far.
USB charger port.
Brush guards.
Jet it , when I got my jet only one place made it out of Oregon. But it helped a lot with the lower altitude and after I put the exhaust on and k&n it seem like I got a few more miles an hour without it wrapping out too high, I definitely didn’t have the lien pop anymore. Now I’m back up to 5800 feet and I’m wishing I had the stock jet back in it.
Discussion Starter #12
Still messing with the air mixture, ordered a 15 front and a 42 rear sprockets.
Mods done so far.
USB charger port.
Brush guards.
I agree with the suggestions so far. Factory jetting is typically on the lean side in recent years so any elevation will theoretically richen it up a bit, so I would guess you're probably optimal to at least 5000'. This is, of course, if you still have the factory pipe and air intake.
1 - 13 of 13 Posts
