1 - 11 of 11 Posts
Hey there,
New TW owner here. I've been lurking this forum for a while actually since I've been looking for a tw for a couple months now. And I just picked one up. Quite happy with it so far too. Picked up a 2008 TW200 with 1700km on it in great condition. Already came with the cycleracks front and rear racks which I was looking to add anyways.
do mind my sweet ass Elite 150 in the background ;)
I'm planning a longer trip come September, a mix of on and off road riding so I'm trying to get a list off accessories I'll need for this adventure and future adventures to come. This first trip should be a couple thousand km's by the end of it. Here's kind of what I have so far. Im not on a shoestring budget or anything but I'm not looking to go broke either. My Idea is to camp along the way so I want to set my tw up with a Rotopax water and fuel pack in the front, build some ammo cams on the sides of the rear. Then strap a duffle bag and backpack on the rear rack, small rolie on the tank. Also interested in finding a solar charge to throw on the front rack since you cant really put too much on it without blocking out the light. Anyways here's my list so far;
Body
-Jimbo shield (if they're available? I just email him?)
-Tusk D-Flex Handguards (ATV Parts, ATV Tires, Dirt Bike Parts, Motocross Gear, Motorcycle parts and Motorcycle Tires | Rocky Mountain ATV/MC)
-Seat Concepts Foam & Cover Kit (Parts + Accessories + Performance = ProCycle)
-MotoLock Tube & Tube Tender Kit (www.thetooltube.com)
-Bag Supports Front + Rear (cycleracks.com > Home)
-Rotopax 1G fuel + 1G water packs & mounts
Luggage (Wolfman Motorcycle Luggage & Bags:)
-Expedition Dry Duffel - Medium/Large
-Small Rolie Pack
-Harness for flat tank
Engine / Electrics (Parts + Accessories + Performance = ProCycle)
-Counter Shaft Sprocket - 15T
-Rear Sprocket - 47T (not too sure about this)
-LED Bulb for Stock Tail Light
-Extra Spark Plug
Tools
-Tire Iron Wrenches
-Inner tubes or patch kit?
-multi tool
-various sockets
-Small air pump
So is there anything that's obvious I'm missing? or is anything here excessive?
Welcome Braden,
I am sure you will get lots of replies. I have a few quick thoughts/cautions off the top of my head:
  • Having 2 gallons of liquid on the front might be too much weight for the front end.
  • I would consider sticking with the stock front and rear sprockets unless you have some special reason to re-gear. Especially if you are going to be spending some time off-road and are expecting to encounter hills and headwinds on-road. Get some seat time with your full load before your trip and evaluate.
  • I would add an inline fuel filter between the petcock and the carb - it is cheap and easy insurance.
Sounds like fun.
Some oversized foot pegs. I got mine off ebay for about $22. Make sure you get steel. Mine fit perfect right out of the box. Took about 5 minutes to install and I was really surprised how much of a difference they made for comfort, stability, confidence, etc...
Regearing will likely be a bad plan with all the gear and accessories you've in mind. Your bike will be considerably heavier and combined with wind resistence you'll find it tough to maintain speed even with stock gearing.
Consider applying the Rotopax money toward an oversized fuel tank, instead. Fuel won't be hogging up valuable real estate and the weight will be where it belongs.
Consider bladder type water storage. It's lighter. more versatile, both expandable and collapsible with no heavy bracketry required. By using more than one you can distribute your water load at will and place it almost anywhere you want and your eggs won't all be in the same basket so ta speak.
Lots of good advice already.
If you're not gonna play with tire air pressure much by adding and removing air for different road conditions, you may want to try "ride-on" tire sealant. Also helps balance the tires.
In regards to your rear rack luggage, I'm thinking of rigging up an old back back frame upright. Might give you some back support as well. Got the idea from seeing a harley with a sissy bar backpack attached.
I'd also like to add, I like using a camel-bak water drinking bladder. Easy access to drinking water while still moving!
Alright,
Thanks for all this advice! Definitely have re-thought my ideas. New plan new plan;
-Keep stock gearing
-small ammo can panniers on the front rack
-Rotopax 1G fuel tank in the back left side or on the rack like Old Betys' Happy Bike (clarke tank is a little over budget for me)
-Use a water bladders + camel pack
-Add a 90° bend in-line fuel filter
-DMO FootPegs
I'm still curious how I could go about getting a jimbo shield. Are they still being made? I've sent him an e-mail.
Newcomers may not be aware of this but Jimbo's real job as a firefighter makes for an. unpredictable and demanding schedule, particularly at this time of year. I hope he wont mind my speaking for him but give him some leeway. He'll do ya up right and you. will love what comes in the box.
Braden
Fuel bladders are the way to go. I have a rotopax system which I've used many times on my F800gs. But have removed it now to use only bladders.
as lizrdbrth said you can move the bladders to any position on the bike. When empty they take up very little room.
OB
1 - 11 of 11 Posts
