I would like to replace the speedometer on my 95 TW200. It looks like the newer (2001-2012)speedometer unit with the odometer is a direct replacement. Can anyone confirm that the newer speedometers will definitely fit the older bikes without mods? Thanks
Yes, the speedo are a bit differend, but the rest is the same.
5Y1-83513-00-00 - Damper between speedo and speedo bracket
TW200 1987-2011
15A-83519-00-00 - speedo bracket
TW200 1987-2011
2JX-83510-A0-00 - speedo
TW200 1987-1999
2JX-83510-B0-00 - speedo
TW200 2000-2011
Regards, Sebastian
Scott,
They're pretty common. The same speedo as the late model TW speedo with the resettable trip meter was standard equipment on other Yamaha models long before it was introduced on a TW. A good source are XT350's and 600's (It may also have been on XT225's and XT550's, but I've never checked). My bike has a, '85 XT600 speedo. Even the lighting pigtail is the same as early TW's.
The drive ratios at the hub are all the same in Yamaha dualsports. A fat 18 is about the same rolling diameter as a 21, and ballpark is about as good as it gets with Japanese speedos.
I don't know how much Yamaha gets for a new speedo these days but I'm pretty sure you could buy a couple of far superior Vapors or the like for the same munny.
Mine came off an XT225, works great. Check Ebay, I see them on there now and then.
Good to know. One of these days we need to start a parts interchange thread for things like this.
