I swapped the TK / Mikuni TW carb for a Nibbi a while back as I noted in my 'picture' thread here 1999 TW - Upgrades Now with Pictures!
I want to bring y'all up to date. I covered the install in the other thread but basically if you have a 2000 or older TW you need to swap out the airbox to carb boot to the 2001 or newer because it is 1/2 longer. You also need to get a single pull throttle and cable.
I originally installed straight from box using their preset set up. It ran well but still ran lean so ...
I switched the main jet to a 120 (came with 110), it ran well but very rich and really sh.. uh, BAD fuel mileage. So ...
I dropped the needle one slot (second from the top now) and changed jet down to a 115 and now lean again so ...
I changed the jet to a 118 and BINGO!
I did adjust the air fuel mixture each time (though it really always came back to about 1 3/4 turn out) and put in a fresh plug so I could diagnose the results.
Very happy with the results and the carb has been flawless throughout, easy to work on and just a solid performer.
It's smooth with faster response from throttle inputs.
