I need help regarding a clutch issue. When I bought my 05 TW used from someone last year everything worked fine and the bike was well taken care of. I purchased off ebay a "slick wheelie" to transport my bike home so I wouldn't have to go through the hassle of registering a trailer. For anyone not familiar, its a device that holds up the front wheel of the bike from the rear tow bar of your vehicle and the rear wheel of the bike just rolls on the ground with the car (gear in neutral of course). It wasn't till about a few hours from driving that it occured to me I should have taken the chain off before driving...I had a feeling something was gonna go bad and perhaps it would fry my clutch. When I came home I noticed the clutch felt a little different but it was ok. I drove around all summer.
It's been sitting almost a year and I've decided to fire it up. Now it's like I have no clutch at all. I changed the oil, cleaned the oil filter, replaced the spark plug, hoping it was gonna fix itself but to no avail. Here are my issues: Clutch lever is very loose, almost not engaging at all. When I put the bike in first with the clutch lever pulled, the bike wants to take off like there is no clutch. If I'm sitting and I put it in first with the clutch lever pulled and my foot on the brake, the bike slowly stalls. So I tested it a little and shifted without even using the clutch a couple times and it felt the same as if I WAS pulling the clutch lever. Also, with the bike off and in first, I pull the clutch lever and the bike won't move. So, obviously, I have no clutch engagement AT ALL.
Yes, the little tension spring on the cable/motor mount is installed correctly.
I've mostly only read on here about clutch slipping but none that focuses on having NO CLUTCH AT ALL.
Any help is greatly appreciated. I've never replaced a clutch or even adjusted one but I guess we all have to learn somewhere.
