1 - 9 of 9 Posts
Just finished install of a kick starter for my 09 TW. While cleaning the side cover of the old gasket I found a small o ring. I am thinking this to be the clutch pushrod o ring that I found reference too on a search of this site. Can some one tell me where this should be placed. Hopefully not behind the clutch basket. I usually end up doing things twice.
Thanks, great forum for a new T.W. owner
The way I understand it is some used models it and some did not I think its nothing to worry about. I did not replace mine
It seems like if you did not remove the pushrod itself, it would be impossible for the o-ring/seal to come out...
I don't have a clear enough mental picture of the assembly to tell you were it goes exactly, but I'm sure someone will come along with the knowledge.
Well Sea Salt
What did you find out on the O ring?
Did not remove pushrod.
Could be the filter o ring. Will check
Thanks
Thanks for the update
1 - 9 of 9 Posts
