1 - 6 of 6 Posts
My Grandson likes to turn knobs and things - and sure enough he grabbed and tugged on the odometer knob on my speedometer -
I have fiddled with it but had no luck on getting it threaded back onto the stem
Anyone know of a shop where speedometers can be repaired?
It is not critical but I dislike having a broken part on my TW
It's LEFT HAND thread. Sure that's not your issue?
JB weld it - might be a little messy for such a small application
Epoxy it - maybe too messy as well
Hot glue - drill out the ID a little bit, glue it, then slam it on
Heat up the stripped ID a little, push it on and let it cure back on the stem?
Junk yard/eBay/Craigslist parts bike/etc. for a replacement
If the knob is actually broke and not stripped, you could try a knob from a lamp. Wrong thread (possibly find left hand thread lamp knobs??) but could be used with the above options.
That knob has left hand threads. It is also hollow.
Sighting down the knob, line-up the end with the threaded post inside the odometer housing. Then start twisting anti-clockwise. Takes a while, but it will grab eventually.
Banned
The curb-side mirror is also left-hand thread. Saves the mirror mount when the mirror strikes the ground or a branch while riding. Yamaha does some weird stuff from time to time, but if you think about the Yamamadness, there is always a method to it.
This site is awesome for so many reasons. I too had mine come off. All it took was typing in Speedometer in the search box and you all answered my questions. Thanks.
1 - 6 of 6 Posts
