1 - 20 of 29 Posts
It looks like carbon buildup mostly, not actual pitting, but it's hard to tell on a little screen. If you mean your engine was leaking on the clutch side, that could've been the entirety of the issue. Was the exhaust smoking a lot? Did it get better when it warmed up? Since you've already got it apart a new wrist pin, circlips, rings, and a hone would be nice. But you should have the bore checked as it could've been burning oil that was slipping into the combustion chamber. Could also be valve stem seals, but in either case there should be smoking, otherwise it's probably just an oil leak. I hope you had more to go on than just an oil leak before you disassembled.
It was burning oil. Lots of blue smoke. I assumed blow by was causing the leak. It would bubble oil out of the clutch shaft on the left side of the engine.
The top of the piston is real pitted especially near the one valve relief. The piston also looks pitted above the rings. I’m wondering if it was too lean?
I am planning to bore it. Would like to have valves serviced too. Looking for a machine shop to do it. I’m in rural SD. Not many machine shops around.
Wonder what it would cost to punch it over size. As long as you have it apart.
Looks like heavy carbon build up rather than pitting on the piston, possibly from a leaking valve guide. Cylinder head should also be inspected by the shop when you locate one. By "clutch shaft on left side of engine" I assume you are talking about the output shaft that holds the small sprocket, left side of bike as you sit upon it? That seal should be replaced too. You can do it yourself in your garage if the shop is too far to comfortably transport the engine or whole bike. Ordering seals, plus any other parts, over the internet can save time and money.
No it’s not the countershaft seal leaking it’s the clutch shaft linkage. The lever that the clutch cable attaches to. It kind of bubbles out like there could be crankcase pressure.
Here is what a new Yamaha piston for a TW looks like:
That clutch shaft has a seal on the top. I think you have to remove the left side cover, remove a bolt that holds the shaft in place, slide the shaft up and replace the seal. I have never done it before so read up on it first. Also, as long as the left side is off replace the shift shaft seal, the output shaft seal, and the support bearing seal that is in the left side cover. Also make sure the breather tube isn't clogged -- actually do that first. Maybe that is the cause of your troubles.
You can get by with a new set of rings and a dingle berry hone job otherwise the magic word is "Wiseco Piston". 67.5, 68.0 and 70.0 mm. The 70 leaves the cylinder wall looking pretty thin but I have not had any trouble with mine. Search ebay "Wiseco 4292" for the smaller piston and "Wiseco 4312M07000" for the big piston.
If you want to keep the stock bore and try a really big hump on the piston, I don't know if it will clear the head or valves, I have a Venola piston which I think uses stock sized rings and wrist pin.
Hmm, there must have been some pretty serious crankcase pressure to be blowing oil out of the clutch lever seal. Was the crank breather capped off or otherwise obstructed?
Oil burning on acceleration is generally the rings/cylinder being worn, and tends to get better as the motor warms up(expands, tolerances close up a bit). Oil burning on decel (high vacuum) is generally valve seals, and tends to get worse as it warms up (thinner oil is more readily sucked through the worn seal).
It's kind of hard to see in the photo but if you can still see remnants of the factory cross-hatch pattern, you should be good to go with a stock bore (67mm) and just knocking the glaze off with a dingleberry or 3 block hone. Most auto parts stores rent these. If it's worn to the point that's no longer visible- or has scarring or other damage, you'll want to bore it.
I'd say go with a Wiseco piston since they're actually cheaper than a Yamaha OEM, and you get a bit more oomph in the low to mid range since it boosts compression- I believe stock is 9.5:1, and the Wiseco is 10.25:1. Not an earth shattering difference, but it is noticeable. I'm not familiar with the Venolia but it looks like it has a bigger hump than the Wiseco, so I'd expect it to be even higher.
The Wiseco piston does seem to prefer at least mid-grade gasoline. On 87, loading it up at low RPM can cause some minor knock. 89 or higher seems to be enough to stave it off.
Discussion Starter #12
Thanks for all the good info! I have a 70mm wiseco piston coming.
I live at 1100 feet. All our trail riding is at 6000 feet. The 114 jet was too rich. I couldn't find a 112 jet so I went with a 110. It ran great. After going with the 70mm piston will I want to change my jetting?
Discussion Starter #13
elime thanks for the pics and info! I appreciate it. I’m looking forward to getting my cyl bored and the new piston installed. Is it common to have the valves ground when one does a piston and rings job or is it not necessary unless there is a valve issue?
While the head was off I would go ahead and inspect the valve seats and lap or grind as necessary. However more importantly I would inspect the valve guides for the possible source of the oil leakage into the combustion chamber. Maybe others can tell at a glance whether the smoke issue and carbon build up definitively were due to worn rings but I sure cannot.
Was diagnostic clues in post #11 helpful in determining that rings were likely the cause of blow-by thus causing oil bubbling at clutch shaft seal and not a clogged breather tube assembly nor leaking valve guides? If so a light lapping of the valves would be good practice while awaiting completion of cylinder and piston work.
That the breather tube assembly did not seem to vent excess crankcase pressure as designed into the air box housing remains an issue to address. I do not think bubbling at clutch shaft seal should not have occurred even with a marginal seal.
If just the cylinder work is done and engine still smokes after a good break in period and procedure then it is not that much work to remove just the head and have the valve guides replaced at a later date.
I like removing the valves and cleaning the carbon from the back side. I like to lap the valves too though some feel it is a pointless exercise I personally think it does some good and is a good idea. Another thing to replace is the valve stem oil seals. If the ones on there now are bad that could contribute the smoke.
And I am with Fred about the breather vent tube might be blocked and not venting enough.
When I swapped in a Wiseco piston along with a stage 1 cam from WebCam, initially jetting required no adjustments. It still started up and ran perfectly fine. Previously (and after) I also had a couple holes punched in the airbox lid, a FMF muffler, and XT head pipe (same as stock, just shiny). I had a 32.5 pilot, 2 turns on the mix screw, and a 132 main. Sea level riding. Starts and warms up quickly, pulls cleanly through the rev range, and still returns about 70mpg on average.
I ran that for a while. One day for some reason I felt the top end wasn't quite as crisp as it could be, so decided to toy around with the main. I tried a #130 first, which I thought was about the same, maybe a touch worse, hard to tell. Then I tried a #135 and it was noticeably better, and top end power was stronger. Power in the 8000+ range was much better even with 15/47 gearing, and maintaining 70mph (true, or about 73-74 indicated) was easy, even up grades. The effect of snapping from 50 to 100% throttle was definitely more pronounced with the 135 than the 130, so I'll be leaving the 135 in. It actually pulled to 8700rpm on flat ground, which was close to 80 indicated, previously I'd never exceeded about 8400 without a downhill.
No idea what the redline on these is, most similar 2v thumpers don't like going much past 9k or so. Downhill I've had it flirt with 9000 and let off at that point.
I attribute it's thirst for a bit more fuel in the top end to be more to the cam than piston, since it actually can breathe up in the 8,000+ range with a cam and opened intake/exhaust.
110 seems really lean even for higher elevation. Stock is a 126, which is pretty lean at sea level and decent for the 3-6000 ft range. Are you using Mikuni jets? They physically fit fine but the numbering scale is different. A 110 Mikuni equates to about a ~125 Keihin/Teikei which would seem more in the ballpark.
it sounds like a head problem not a cylinder problem to me remove the valves and lap it replace the valve seals put it back together and you will be good to go
Discussion Starter #19
I got my 110 jet from Bike bandit. I have the stock 114 in order. Not sure where I put the original one that I took out. The 114 stock jet was definitely too Rick at 5000-6500 feet.
1 - 20 of 29 Posts
