1 - 13 of 13 Posts
· Premium Member
2004 TW200, 3000 miles
Nose Chin Eyebrow Mouth Facial expression
Nose Head Hand Arm Facial expression
Outerwear Sleeve Automotive tire Motor vehicle Gesture
Glasses Vision care Helmet Hard hat Sunglasses
· Premium Member
*sigh....
New plug'll be here Tuesday.
· Premium Member
I bought a CNC plug from either amazon or ebay.
Dont remember which. Much easier to work with over the stock drain plug, and only 10 bucks.
Yep, I've got one on order.
· Premium Member
Take a chisel and a hammer, put the chisel on the outer edge at an angle so when you strike it it will unscrew the plug, and hit the chisel with the hammer. The plug will come loose and be easily removed. At least it did for me when all other methods failed.
Manuel specs 32 foot lb for drain plug. Use a new o-ring and 25 FP Works.
OFG
· Premium Member
Discussion Starter · #13 · (Edited)
Yessir, that's the plan when I have the new plug in hand.
OFG
32?! Good god, no wonder it won't break free! I don't think I've ever torqued one down before. I've always just tightened it down until the O-ring deals, then nip it up maybe a 1/4 turn. Maybe 20lb at most.
1 - 13 of 13 Posts
