21 - 23 of 23 Posts
2019 Yamaha TW200, 2021 CRF300L Rally, 2021 Ford Bronco
Torque limiting, yes. But unless it is some high end dealership / race car they do not precisely torque lugnuts, Different cars / models have different values and they do not reset for every one. Rattle guns normally have adjustable ranges and overtightening has as many pitfalls as under tightening. Still I stand by my assertion that just because a fastener has a certain torque specification does not mean that it must be followed precisely.
i work as a Mechanic at a shop that also has a tire side. The tire guys torque every wheel to spec. They do not have to adjust torque on the wrench, they have a setup on the wall with 10 torque wrenches set to different torques by the manufacture, that gets calibrated regularly. They also have a chart on the wall with all the different vehicle torque data. First they run them up with a torque limiting socket, then when its back on the ground, they use the torque wrench of the correct torque. Its a very good system. Although Mistakes still happen in every industry
1999 TW200
There are exceptions to every rule. I can and have gone to major name brand tire shops around me and none of them torque to specs.
2019 TW 200, 2004 XT225, 2005 XT225,2022 KLX140L
Different bike, she fell, my bolt busted off.
Thanks! We had a blast. I've been super busy with work so we didn't get to do much this summer, next year should have a good bit more trail riding mixed in. Top and bottom pics are Cordova pass, middle pic is hwy 13 out of Pickett Wire.
I thought your pics looked like a familiar area, Been up there a time or two, since it is only a couple of hours away. Btw. I used a torque wrench on those same bolts only once and spec seemed way to tight. I simply do it by feel and have not had any issues as of yet.
21 - 23 of 23 Posts
