Ive got an issue that popped up one day in the middle of riding. I was on my way home from a great weekend excursion on the TW when all of a sudden I started surging anytime I gave the throttle more than 1/4-1/3 turn. It was almost like I was running out of gas. I checked that I had plenty of fuel remaining (had close to 70 miles on that tank of gas already), I did. I limped it home thinking it had to be a carb issue. Upon my return home,the major thing I noticed was the throttle cable plate had one screw missing and the other was barely attached. This must hace been the issue for sure. So i promptly replaced thd missing screw and tighted the second. Additionally I tore the carb all the way apart and cleaned all jets and even found a questionable gasket on the top of the carb, which I changed out. Putting it all back together things were working fine (slide, float, etc).
BUT! The bike is still surging at the 1/3 throttle position. What else could be causing the issue? I thought bad gas, but I had run nearly 1/2 tank on the gas in question. Thought could be something partially clogging the screen on the petcock, but would that change when I switch to reserve? And when the bike is stationary, I can rev it to the moon without hesitation. I have 8000 miles on the bike. Could it be the valves? I checked the at about 4-5000 miles and they were within spec. I am out of ideas. Please someone with more carb/motorcycle skills offer their thoughts.
Thanks guys!
Thanks guys!
