1 - 15 of 15 Posts
Is there really any difference In a new vs older TW? I have an 89 with a few mods and was looking at the new ones in the dealer the other day.. Other than shiney paint they looked identical! Tried and true :)
Yes, there are a few differences, you see them mentioned here from time to time. The front brakes got upgraded to disc, kick starter went away, for instance. But by and large they remain the same reliable machine they started out being. For me that really is one of the attractions.
Hello ya'll.
I'm new here. I just got a 1999 TW200 with 3800mi. It runs good and it is a lot of fun! I am stationed in FT. Gordon and there are a lot of trails on post. I decompress for about 30 mins every day after work on the trails! YEAH!
How many miles should I expect to get out of the engine before it needs a rebuild? Where is the most economical place to order new tires? (The OEM ones.) Do I need tubes in the tires? or just new stems? Can I download the maint/repair manual online for free?, Where?
Any tips on care/maint on the bike will be appreciated.
Thanx,
Pathfinder
:cool:
Hello ya'll.
Thanx,
Pathfinder
:cool:
Change the oil often and don't get it too hot, keep the valves and cam chain adjusted and it should last a very long time before rebuilding becomes necessary. I prefer full synthetic Mobil 1 4T racing oil made specifically for motorcycles with wet clutches.
Go to the technical write up section and you can download the service manual there.
The stock rear tire can be bought for right around $100 and a few places do free shipping. You will have to search recent threads over the past month or so and a few guys found some good deals but I don't remember where the best was. As far as the front tire goes I would toss the Bridgestone and go with a Shinko 244 Golden Boy in 5.10 X 18. TWs love this tire on and off the road and it is cheaper than the stock one. These tires take tubes so if you need new tubes get them with the tires. Most of us are using Ride On (Motorcycle) tire protectant and ballancer when we put new tubes and tires on. You will need 3-8 Ounce bottles, 13 ounces in the rear and 7 ounces in the front.
When you wear out the stock roller chain and sprockets it is a good idea to replace them all at the same time. O ring or X ring chains last ten times longer and require a lot less adjusting and maint. You will need new seals when you replace the front sprocket and a side cover gasket. Buy a few oil filters and put an in line fuel filter on it and you should be pretty well dialed in.
There is a new sticky showing the on line suppliers we seem to like the best at the top in Performance and customization, right under that is the front tire thread.
Welcome to the forum and thank you for serving our country, lots of vets here.
Everything GaryL said is spot on. I would probably just go ahead and replace the tubes if you are replacing the tires. Rubber gets old. Be nice to start off with fresh everything. That way you know what you are relying on.
Obviously there are alot of different places to find and order parts etc but I have had good luck with Motorcycle Superstore...just my .02 cents
Thanks for all the tips! Never though of filling the tires with sealant! My TW got As new o ring chain/sprockets/battery/break shoes ECt about a year or two ago.. Even though the brakes still suck.. Any tips for improving them or making the bike stop rather then just slow down? :)
The rear brake is the same as far as I know but the front flipped to a disc set up around 2001. Some swear by them while others would quickly trade out the front disc for a kick start that was deleted the same time the disc was added. You can buy all the parts on the auction site but I think it requires different forks, different wheel with disc and the master cylinder and reservoir on the bars. Not sure it would be worth the expense. I have heard it said that its a good thing TWs don't go fast because they don't stop for shit! You can also modify the rear brake rod and lever to the longer ones found on the XT 350 which adds a little leverage in the back.
I believe this was the post GaryL was thinking of regarding tires and prices. http://tw200forum.com/forum/performance-customization/9816-best-deal-options.html
There is another thread that qwerty posted his favorite supplier in and they do free shipping. I bought my new tires at Rocky Mtn. $98 for the rear Bridgestone and $58 for the front Shinko 244 with free shipping. Got the HD tubes from Lytleracinggroup along with Ride On, X ring chains and new sprockets X 2. All good guys and super fast shipping.
That's it, Americanmototire.com. good prices and free shipping.
1 - 15 of 15 Posts
