Chill, people. Different uses have different filtration needs. If one does not know enough to make an educated decision, better to stay with the stock system. Most mods to vehicles seem to be misapplied and actually cost overall performance and create problems because they compromise the balances built into the system, while making more noise.
The TW makes one horsepower per cubic inch, a stratospheric output ratio considering the 1970's technology upon which it is built, mind-boggling considering the output ratio is developed with fuels 15 octane points below that required by comparable auto engines of the period. It is a very high performance engine for its day, and that performance was generated by very carefully choices of tuning parameters such as intake tract volume, airflow rates in the intake and exhaust, and incorporating a reverse cone megaphone exhaust, all while meeting mandated noise and spark arresting functions, under constraints of stylists and accountants. Do you really think you can do any better?
