1 - 14 of 14 Posts
Anyone have any pictures of the engines by their lonesome? If the XT engine will work in the TW and just needs a longer shaft, I can have one machined pretty cheap or even an adapted made.
I guess I would like to see what it TAKES to get one of these to fit.
I put the gearbox XT 225 6 speed, in a motor TW125 ...
This requires making a new axis of gear ...
How have you set the chain ratio? By that I mean have you got an extra gear higher than the old 5th gear or a 1st lower than the original or have you set it as a bit of both? I appreciate that yours is the 125cc.
I would be very happy with a 6th gear higher than present 5th.
I don't think it needs another gear, it can barely pull 5th now, it needs another cylinder more.
christddel's engines usually have a larger displacement too (up to 300cc for now, if I recall correctly)
Yes, Very true, my engines are (often) more than 200cc
No problem for make an engine 230,236,243,259cc
More difficult "$$$..." to 270,289cc
It's bigger 300cc engine for TW ...bore 77mm, stroke 64,5mm = 300,2cc
It is in the workshop, several technical problems, and it will turn ...
1 - 14 of 14 Posts
