1 - 10 of 10 Posts
Since you're using a 125 I'm assuming an early-style carb.
XT350's use a 125 main and #42 pilot in their main (primary) carb. Same basic carb.
The jets used in the secondary carb won't swap.
Handy list. We need to swipe dat.
Here we go, swiped from a post on Advrider, who swiped it from a post on ThumperTalk:
Jet sizes and part numbers that fit the XT 350 carb:
PRIMARY MAIN JETS
288-14343-35-00 = 70
288-14343-39-00 = 78
288-14343-40-00 = 80
288-14343-41-00 = 82
288-14343-42-00 = 84
288-14343-43-00 = 86
288-14343-44-00 = 88
288-14343-45-00 = 90
288-14343-46-00 = 92
288-14343-47-00 = 94
288-14343-48-00 = 96
288-14343-49-00 = 98
288-14343-50-00 = 100
288-14343-51-00 = 102
288-14343-52-00 = 104
288-14343-53-00 = 106
288-14343-54-00 = 108
288-14343-55-00 = 110
288-14343-56-00 = 112
288-14343-57-00 = 114
288-14343-58-00 = 116
288-14343-59-00 = 118
288-14343-60-00 = 120 (XT 600 OPTION)
288-14355-61-00 = 122
288-14355-62-00 = 124 [AKA 288-14343-62-00]
288-14343-63-00 = 125 (XT 350 STOCK)
288-14355-64-00 = 128 [AKA 288-14343-64-00] (TW200 01-07 OPTION)
288-14343-65-00 = 130 (XT 600 STOCK)
288-14355-66-00 = 132.5 [AKA 288-14343-66-00]
288-14355-67-00 = 134 [AKA 288-14343-67-00]
288-14343-68-00 = 135
288-14343-70-00 = 140 (XT 600 OPTION)
288-14343-73-00 = 146
288-14329-74-00 = 148 [AKA 288-14343-74-00]
288-14329-75-00 = 150 [AKA 288-14343-75-00]
288-14343-76-00 = 152
288-14329-78-00 = 156 [AKA 288-14343-78-00]
288-14343-80-00 = 160
288-14329-81-00 = 162
288-14329-82-00 = 164
288-14329-83-00 = 166
288-14329-84-00 = 168
288-14329-86-00 = 172
288-14329-87-00 = 174
288-14329-88-00 = 176
SECONDARY MAIN JETS
30X-14343-40-00 = 80
30X-14343-50-00 = 100
30X-14343-51-00 = 102
30X-14343-52-00 = 104 (XT 600 STOCK SEC MAIN)
30X-14343-53-00 = 106 (XT 350 STOCK SEC MAIN)
30X-14343-55-00 = 110 not sure if available
30X-14343-60-00 = 120
30X-14343-63-00 = 125
PILOT JETS
30X-14342-19-00 = 38
30X-14342-20-00 = 40
30X-14342-21-00 = 42 (XT 350 STOCK)
#48 pilot 43f-14342-24.
#140 main 288-14343-70
You may want to "un-swipe" all of the "30X-" Main jets. They're for the secondary carb on an XT and won't interchange.
The 4-valve XT's (350's, 550's, 600's) Use two carbs. The main carb is a Tekei slide carb pretty much like ours, but the secondary carb is a CV type and has no pilot circuit, floats or float bowl and uses different style mains. It's its own critter.
Most of them probably aren't available any more but it could confuzzle folks.
The pilot jet numbers should be valid.
Good info.
In case this comes up in a search, some pics of the pilot location and the bigger pilot itself:
1987 Yamaha TW200
I'd like to resurrect this old thread (as I am fond of doing) to ask if anyone really noticed a difference in the power band after swapping pilot jets. Wouldn't turning the stock #40 out a few more turns be equivalent to going up a size? It doesn't matter in any case as I've ordered the pilot jets, but I'm just curious.
1 - 10 of 10 Posts
