1 - 20 of 34 Posts
If it runs great and only needs tires, the rest is probably just fine.
I found a 2002 TW that has 140 miles on it and has been garage stored. Are there know problems that will cause me problems prematurely. First thing would be changing the tires. It just had its 100 mile service and suppose to run great. Thanks for your help.
are you in the sacramento area?
if so, i'd say $3000 is on the steep side for a totally stock 2002, regardless of the low miles.
3K would be about it... I paid 2,000 for my 2003 Dub about 2 years ago.... It had unknown miles on it because the speedo was hacked to get it into calif. The tires looked new. The bike was used to run MJ out of the mountains up around George Town, CA so it was DIRTY. I cleaned the carb, adjusted the valves, changed the oil, serviced the chain and replaced the tires. That is about it....
Read about doing your own service... Know about the wrong oil filter problem...if you decide to get it.
Welcome to the forum!
I edited this because I checked what I paid for it... Thought it was 2.5K.... Paid 2K for it...
Jim
And the speedo has a hole in it.. We are talking about it.
Uh? A hole in it? Where?
Be careful this might be an out of state bike! If it is the Speedo has to have over 8,000 miles on it... If not Calif DMV will not let it in... Check the registration and make sure it is a CAL bike!
The tires should have the little "new knobs" on it with only 140 miles on it....
Jim
Discussion Starter #11
Congrats. It looks great.
Well I finally got it and it runs perfect. Took it out for a 10 mile trail ride with top speed of 15 mph. View attachment 96241 View attachment 96249 View attachment 96257
Nice looking bike for sure. I love clean and even more after you get them dirty.
Take note here and this is for all you new and some old TW owners. The middle picture showing the battery, there is a rectangular compartment right behind the battery. This is NOT a STORAGE compartment! I have seen guys stuff rags in there and even stuff like a wallet or pack of smokes. This IS the air intake for the air filter box. It is also a place the mice love to build nests so just be sure to keep it clear of any obstructions.
Best of luck with your new to you TW and do let us know what work the dealer did perform. It is highly recommended that every owner always checks the oil filter before you install it and immediately after anyone else like a dealer installs one. On the engine side where the filter is inserted there absolutely must be 4 tiny holes rather than another often mistaken filter that has just 2 tiny holes. If I were to take my TW anywhere for an oil and filter change I would demand to inspect the exact filter they will put in before they do the change. To the top left of the spark plug in the jug there is a 10mm bolt that is a bleeder to prove you have oil flowing when the engine runs. Not meant to be removed but just cracked open for a few seconds while running to assure the oil is flowing to the head.
Discussion Starter #17
Well do not leave us hang... What was the resolution!
Jim
I ended up paying $2750 for it and in the CA market I felt that was good and it also matched coloring on my motorhome. From what I was told the dealer rebuilt the carb, in stalled new battery, and changed the oil. The owner rode if back from the shop, 10 miles, and I also rode it so figured the filter was installed right since it hadn't seized yet. Have taken note to install oil drain plug assembly and oil filter properly. Will check out the oil bleed plug today along with changing the brake fluid. The tank had no rust which surprised me. Owner could not find the owners manual so I downloaded on but would like to get an original one along with a shop manual. After my little 10 mile trail ride the other day it had no leaks. So I am pretty happy so far. Will take it out today with less air pressure maybe 16. Had 20 psi in the other day and it was pretty rough. Have ordered seat pad and big pegs. Need risers, hand guards and larger diameter grips. Ideas would be appreciated. Thanks, Mike
If you're not looking to 'pay for a name', I'm pretty happy with the eBay handguards that I bought after SkinWalker posted a link to them. They do the job, and appear to be plenty beefy. It's not like they're a precision part where tolerances are critical... They did need to be put in a vice and given a few yanks to adjust the alignment but that's to be expected... One added benefit that I didn't even think about was the amount of wind they deflect off my hands, thereby keeping them warmer on chilly days.
A 90 degree fuel filter would be a good idea IMO. There's a screen on the petcock, but stuff that could squeak through that screen could still ruin your day if it made it to the carb...... I put one on because I nearly always fuel out of a gas can, and you never know. And I've thrown a couple extra in my tool bag along with a length of fuel line...no hose clamps; I'll use zip ties if I have to change anything on the trail.
I was new to 2-wheelers when I got my TW last fall. I wasn't used to the bike and I was always on muddy roads or wet grass/leaves , and the front end just wanted to be everywhere but where it was supposed to be. Over the winter I put on a Shinko 241, and it feels like a completely different bike...the front feels stable and planted now. I'm not saying you HAVE to toss a perfectly good front tire, but all the posts that tell you to do so are not wrong. I forget what your yours is but you might be at the point where you should replace the tires just due to age....
There's a great post that explains that strip of foam under your seat, what it's for, and why you want to replace it if it's gone.
There's grease zerks on each side of the swingarm.....stuff like that often gets neglected.
I'm new to these things but I already know that now that I have a pelican case on the back and a tube for the Tenkara rod mounted where most folks put their tool tube, this bike is going to suit my needs just perfectly.
I don't know exactly how long you have to ride with the wrong filter before it seizes up, but a couple easy rides may NOT be enough. Lean it over on its side and you'll only lose a few drips of oil. For the small amount of work it is, check the filter.
At the check plug, don't expect oil to spray out or anything at idle. You'll likely loosen it off to the point where you THINK there should be oil spraying out, then start to panic, then oil will begin to drool out. Id that happens, you're golden.
I added big pegs over the winter. Yesss.
Discussion Starter #19
Changed brake fluid today. After 14 years setting it needed it image.jpeg image.jpg . Also added a power outlet for slime air compressor and charger image.jpg . Backed the oil check plug and had ozzing oil at idle so good there. Checked on a Shinco 241 tire today. I am assuming that it is the 4.00 -18 size. Can get it for $55 here.. Modified my floor jack so I could lift the TW. Works good but still have to a couple more mods on it. image.jpeg image.jpg .
Took it out for another trai ride today but this time I had 13 psi in the front and 16 in rear and it sure handled a lot better��
Changed brake fluid today. After 14 years setting it needed it. Also added a power outlet for slime air compressor and charger View attachment 96409 . Backed the oil check plug and had ozzing oil at idle so good there. Checked on a Shinco 241 tire today. I am assuming that it is the 4.00 -18 size. Can get it for $55 here.. Modified my floor jack so I could lift the TW. Works good but still have to a couple more mods on it.
This is a great idea to modify a floor jack. I hope a lot of people see this because the ways of lifting a TW is a subject which comes up quite often. Very nice, thanks!:icon_thumright:
1 - 20 of 34 Posts
