Hi guys,
I'm in need of a little technical help, an unfortunately, electronics aren't a real strong point for me. I recently replaced the chain and sprockets on my SO's 2006 TW. After getting everything back together I tried to start the bike with no success. I narrowed things down pretty quickly and discovered I wasn't getting any spark. I did a little research and gathered that I had probably crimped one of the wires when I put the cover back on.
I took the bike apart again and discovered that I had pinched the "pulser coil" wires. Actually, they had been severed straigt through on both the red and white wires (brilliant, I know). Well, I got to work and spliced in a few wires, soldered them, wrapped the wires in the shrinking tube stuff, taped them all up, put the cover back on being very cautious this time.........Ahhhhhhhhhh!!! Still no spark.
I took the cover off again and honestly, everything looks really good. I'm comfortable with my solders and all. After talking to my pop, who knows just enough to be dangerous, he suggested that the solders could be causing enough resistance to interfere with normal function. I have a volt meter, but I don't really know what I'm doing with it. Can anyone tell me if my fix "should" work? If not, I'll order up the Pulser Coil and replace the whole thing. If soldering shouldn't be a problem, how would I test the connections to see if my fix is solid.
Thanks so much for your help!!
Julia
Julia
