1 - 6 of 6 Posts
Out of these two scenarios, which would result in Richer running bike? Assume humidity is at 50% for both of them.
3000 foot Elevation, 50 degrees F
Sea Level, 90 degrees F
Which would be richer? By about how much? Just trying to get an idea of how much temperature affects jetting compared to elevation.
The air at 3000ft @ 50F is less dense than 0ft @ 90F, so 3000ft @ 50F runs richer
I can understand thermals, but I don't know enough about different jet sizes to tell you how much of a difference it'll make to your bike's performance.
*Edit: This is assuming constant humidity, which won't necessarily be the case. If the higher altitude is less humid than the lower altitude, the difference between the two scenarios is smaller.
Here are some more "calculators" for jetting. Interesting for some, intimdating to others. Calculators Or you could do what most of us do, just ride it.:D
Reactions: admiral
Quick, silly answer: sell your bike and buy one with EFI.
LOL, just kidding (mostly). I don't have a clue. This is why I refuse to ever touch the settings of a carburetor. Sure it can be improved, but it can also really be screwed up (and even "improvements" are likely to be detriments in certain circumstances - even just considering performance/optimization). I just leave them bone stock. I figure you won't have an optimally running bike in any given scenario, but you'll have a running bike in any given scenario.
Also, how many miles do you currently have on the 919? 70k is pretty sweet.
Reactions: saabbug
Jeeezzzz K.J. Your a party pooper!:p Screwing around with things best left alone is part of the game.
1 - 6 of 6 Posts
