1 - 12 of 12 Posts
I recently did a hollow mod on my bike and installed a cone type air filter. Obviously, I'm now getting a lot more air, and was wondering, do I need to increase gas flow or decrease? The bike runs ok, but seems a little sluggish at low rpm's. Anyone who's done this, approximately what size jet did you install?
What year is your bike? There are two styles of carburetors, depending on the year. 1987-2000 is one style, and newer than that is the other.
I would advise you to buy 2 or three different sizes of jets. If your bike is pre 2001, I believe a 114 jet is stock, and then I would buy a 116, 118, and 120 or so. I don't know much about the newer style carb as I've never owned or seen one. Mess around with the different sizes and see what works best for you. I am running a uni pod filter and am running a size 115 jet on my 98, but I live at 5500 feet, so at sea level I would go much higher.
Welcome to the forum!
Zack
Zack, it's a 2012, so I guess I need to find out the stock size and then buy up 2 or 3 sizes. Thanks, it's a start.
Stock main jet on the newer CV carb is 126 on the non-Caifornia, and 128 on the Cali carb. A130 main jet seems to work well on a TW in a stock configuration...might be a good starting point.
Generally, more air means you need more fuel.
jb
If you want it to run better with better throttle response at lower RPM's replace the pilot jet with a #54 From an XT. It also starts easier and warms up faster. I did that mod with a completely stock motor and I still get 77-80 MPG.
I forget, what is the stock pilot jet size? Do the two different styles of carbs have different pilot jets? I should know this but a vicious vortex of forgetfulness enveloped my brain just now.
Zack
Zack
Stock pilot jet for the CV carb is a #31.
This is a #34 should the OP wish to try it.
jb
I switched my main jet out to a #130 ( yes, I shimmed the needle and turned out the pilot screw) and I'm between 400ish too 1200 ft above sea level and the bike "seems" to run well . I presume if it is running well ,don't mess with it . TW starts fine, so ,me changing out the pilot jet to a larger size could open up pandora's box.....right ?. TIA
....... I presume if it is running well ,don't mess with it......
AMEN!
Hi Frog,
If you need to turn your pilot screw out more than 3 or 4 turns, you may need a larger pilot jet. This should not be necessary on a stock bike, and may indicate there is a problem with the pilot circuit.
The OP is doing a hollow mod, so he will need to experiment with different jets, and go through the tuning procedure with each change, to account for the increased airflow.
jb
Understood jbfla ,thanks . I'll just leave well enough alone ,as stated above the bike run's well , as far as I'm concerned ...... no surges ,burps ,farts of annoying traits : ) .
There seems to be a lot of carb tuning question threads right now in the Tech help section, as there usually are, yet nobody seems to be finding the http://tw200forum.com/forum/technical-write-ups/591-carb-tuning.html sticky. Find it, read it, follow it. Whether doing a hollow mod or just trying to eliminate the stock lean condition, that guide is awesome. It gives jet part #s, procedures, wisdom, and it will save you headaches.
As for this OP and this situation, you will probably need to go with bigger jets. I think you will want to try that #34 pilot and a #132.5 main. Just my guess. Here are the part#s for the range of jets:
2001+ Main Jet#:
288-14343-63-00 = 125 (TW 01-13 STOCK SOME)(LEAN, GOOD FOR HIGH ALT. >6000’)
288-14355-63-00 = 126 (TW 01-13 STOCK SOME)(LEAN, GOOD FOR ALT. 4000-6000’)
288-14355-64-00 = 128 (TW 01-13 OPT, CA MODEL STOCK)(GOOD FOR FUEL ECON)(ALT. <5000’)
288-14343-65-00 = 130 (TW MOST POPULAR OPT.)(NEUT-RICH, ALT. <4000’)(XT 600 STOCK)
288-14355-66-00 = 132.5 (RICH, GOOD FOR VERY HIGH TEMPS, LOW ALT)(STOCK IN AUS & S. AFRICA)
288-14355-67-00 = 134 [AKA 288-14343-67-00]
288-14343-68-00 = 135
288-14343-70-00 = 140 (XT 600 OPTION)
2001+ Pilot Jet#:
5LB-14342-65-00 = 31 (TW 01-13 STOCK)
5LB-14342-17-00 = 34
43F-14342-19-00 = 38
1 - 12 of 12 Posts
