I have recently acquired and started up-grading a 2010 Tdub.
I consider it pretty complete with he ecxception of a couple tool and fuel tubes, the 241 for the front, and the "new condition" Stainless DG-0 slip on muffler and 1" quiet core insert that I scored here on the forum which arrived today in the mail late this afternoon.
Not being real familiar with aftermarket exhaust up-grades other than on my present and past Harleys and the 900 cc Triumph America I'm also riding at this time, I do know that after exhaust up-grades were made to all of those, rejetting carbs, or in the case of fuel injection, re-mapping on the computer was required. However, this was all preformed at the shops with dyno's required to achieve desired results.
Is this goung to be the case with the carb on my Tdub (?) and if so, what do those with DG muffler equipped bikes recommend as to new jets required to make it all work well together ? I'm asking as I plan on doing it myself do to the ease of getting to and removing the carb.
So far I have done the following and think I'm getting close to the end as far as up-grades go:
Protaper "Hight" ATV bars and Protaper grips
handguards
ricochet aluminum skid plate
DMO pegs
Cycle Rack ( rear rack )
the DG exhaust goes on in the AM
the 241 is on order.;)
What if anything, am I missing to be ready for spring riding in the nearby Cascade Mountains and somewhat distant desert areas of central WA. ?
thanks,
excalibur
It looks like you are getting set up nicely! You mention a lot for the bike, but nothing about gear for yourself. That's equally or more important than the bike stuff, IMHO. Hopefully, you've got it covered, but we can recommend stuff if not. I gear up thinking I'm going down at least once on every ride, so it hurts less or not at all when I do.
I've never used an aftermarket can on the TW, but I don't think it moves much more, if any more, air than stock due to the small intake throat. I have been running the stock 126 main jet since I'm often at elevations over 4500' in the mountains or in Utah. If you plan to stay below that you may want to play around with the carburetor settings and jetting. Here are links to the relevent threads in our Technical Write ups section.
First, familiarize yourself with the carb... http://tw200forum.com/forum/technical-write-ups/881-tk-carb-photos-parts-identification.html
Next... http://tw200forum.com/forum/technical-write-ups/591-carb-tuning.html
Here are the OEM part numbers for jets. It is highly recommended to purchase the OEM jets. Many aftermarket kits have unfavorable reviews and/or come with jets that are a different numbering system than OEM, so it is difficult to narrow down what is what. I would recommend purchasing the 128, 130 and 132.5 main jets, as well as the #34 pilot jet. They are cheap enough to have on hand for whenever wanting to test jetting. Get them from your local dealer, or your favorite online retailer like Boats.net: Outboard Motors, OEM Marine Parts, Boats for Sale... http://tw200forum.com/forum/technical-write-ups/14969-tw-carb-jet-part-s.html
I bought my bikes cheap because the PO s had trouble rejetting the carbs after installing DG pipes. What worked for me at sea level is 130 main jets, turning out the pilot screw @2 1/2 turns, putting 3 - .02” washers under the spacer on the needles and also for easier cold starting I put in 34 pilot jets,
The washers really made a huge difference in low to midrange acceleration. They had also modded the airboxes by drilling holes in them but I used electrical tape to close them up.
I believe Tweaker's jetting as described also worked quite acceptably on a several rides above 10,000 ft. elevations.
Fred I did try rejetting for the Sweetwater ride at 8-10,000 ft. I changed the main jet to 126, pilot to 31 and removed some washers. But it still wasn’t right although it worked. I am still figuring out high altitude jetting. It takes a little time to get the right combinations and I wanted to ride instead of mess with the carb. I did try opening the holes in the airboxes too but am not sure what difference it made.
