1 - 8 of 8 Posts
Nice, doesn't look like it has as sharp of edges and corners as a competing stamped rack. If installed inverted it might cradle a day-pack nicely.
The major concerns are that it looks like it's for the "Givi" top box - and the mounting points are basically on the sub frame - which gives you a weight loading of around 7lbs (minus the weight of the rack)
Shove a top box on there - and now the weight restrictions drops to 5 and a half - good enough for a helmet and water proofs - but not much more
If you are going to spend that much money on a rack - you could do a lot better - if you want a low profile for a six-pack, then take it .......
I have one and it is good for what it is and if you don't plan on hauling too much. I am pretty sure I will be replacing it with the cycle racks.
Do you want to sell it?
1 - 8 of 8 Posts
