1 - 11 of 11 Posts
Or could it be the grease zerks need some grease for the swing-arm.....just a thought . It could be the rear mono shock ?.
Couldn't hurt.. Our two dubs don't squeak.... Both of them have a clunking noise coming from the front that puzzles me ?????????? Maybe someone will have the same issue.. Good luck. OMM.
I heard about the front clunk that many have said they have with no solution or fix. My front is clunk free but the rear shock definitely has a squeak. Will hit it with WD 40 to see if that gets rid of it.
grease the bolts, then a shot of WD around the bushings, done.
A couple years ago I soaked all three of the rubber mounts on the gas tank with PB Blaster and that eliminated a squeak. I also add a drop to the gasket on the fuel cap. I like PB Blaster.
I was going to suggest stop riding over bumps, but that point is moot. Back to the forum...
I'm catching up on some good stuff, and loving the humor.
Crispy Knuckles...
Fred doing okay?...
1 - 11 of 11 Posts
