The front lights on the TW are three-wire and the rear are two wire. The front ones have a dual filament bulb and the rear ones have a single filament. You can't put the rear ones on the front because you wouldn't have the running lights, as required by most state laws. You can put the rear ones on the back, and just have an extra wire for the running lamp, that's not used. If you break a rear one off, and need a replacement, keep your eyes open for both front or rear signal lights. A lot of times the front ones are more plentiful, since most people break the rear ones.
