Hi Dave,
Nice work on removing those ribs!
Yes, Yamaha's parts diagrams and service manuals are notoriously bad and full or errors. And they were probably able to save a nickel by not machining the end of that shaft.
I would not worry too much about not having an oil feed to that idler gear. It is only lightly loaded for about 1/4 of a revolution when you kick it, and after that it is just freewheeling for the rest of the time. That idler gear also has a self-lubricating oilite sleeve which probably gets a good bit of splash lubrication and oil mist from the spinning clutch pack.
However, if this issue will keep you up at night, here is another option. Since you will already be cutting a C-clip groove into the end of that shaft, you could use a cutting wheel to carefully cut into the shaft where the hole should be. Go just deep enough to break through to the inner diameter of the shaft so that the pressurized oil has a path to reach the idler gear.
On the bright side, your crankcase is already machined so your kickstarter will slip right in!
Brian
Brian
