Over charging problem.
My bike is from 1996, the whole electric system is from 2008.
The only part that was left over from the 1996 electrical system was the regulator /rectifier and it worked fine for the last year, with the 2008 system.
Since last weekend the voltage goes up to 20-21 volt, with the lights on to 18-19 volt.
I measured between the 3 white wires and got 3 readings of 0.9 Ohm.
The 2001+ manual mentions that it should be 0.5 ~ 0.7 Ohm
Measured between the white wires with running engine and the regulator/rectifier connected is 16 volt AC, constant, no matter the rpm,high and low rpm is the same 16 volt.
Measured between the white wires and chassis, with ohm meter, there is no short. This of course with the plug disconnected.
Measured between the white wires from the alternator with running engine and disconnected the voltage goes from 40 volt and up when accelerating, so the alternator should be good.
With another regulator/rectifier, the same result.
With a different battery, the same high voltage.
This is a simple charging system, 3 white wires from the alternator to the regulator/rectifier and a red wire to the battery.
It looks like it that there is no apparant reason why this is going wrong.
The only thing that changed in last weekend, when this happened,
is that the bike was in the repair shop of the Yamaha importer where a new rear shock was installed.
Maybe if I put the old rear shock back in and the problem will go away?
That does not make sense, but the whole problem does not make sense , so far.
I got another regulator/rectifier to try out, with the same result, high voltage output.
The replacement regulator /rectifier’s are both from a XTZ750, in principle that should work.
This XTZ regulator /rectifier did work before on the 1996 electrical system.
By placing a lightbulb in line, in the red wire that goes from the regulator /rectifier to the battery,
the voltage got down to 15.5 volt . The lightbulb has a resistance of 0.4 Ohm.
Maybe, by placing a resistor of 0.5 Ohm in line, the voltage will go down enough so that I can ride the bike.
When I order a new regulator /rectifier it will take about 2-3 weeks till it arrives here and I need to ride the bike on my commute to the job.
Now I have a question, is there any known difference between the before and after 2001 regulator /rectifier?
Yes I know, that's a difficult question, its a black box and hard to know what's in there.
