So I finally pulled off the carb. That's a pretty tight fit, at least more than what I thought it was going to be.
The only part I had a problem with was taking the return throttle cable off. It has a nut(1) that is held secure by the bracket and then the cable has a nut(2) on the end of it. But when you turn nut(2), the whole cable turns with it. I had to turn and turn while holding onto the cable so it didn't spin back to the original position, until it gave me enough room to loosen nut(1). PITA. What am I missing, how can I do this more easily?
