1 - 14 of 14 Posts
I've searched high and low here for info on how to rewire the headlight.
No success.
I want the light OFF when the switch is on LOW beam.
And I want the light on HIGH, when the switch is on HIGH beam.
Any help is appreciated.
Cut or disconnect the low beam wire in the harness behind the headlight.
Remember that wire will still be hot when the switch is on low beam. If it's a male connector you'll want to insulate it.
[quote name='Fort Payne' date='04 April 2012 - 11:59 PM' timestamp='1333598376' post='41829']
Hey Truelight, after the mod does it still click into low beam or do you find yourself turning the light off by accident when trying to dim them?
[/quot
A toggle in the instrument cluster to turn off the brake/tail. Now we are talking!
Greetings, I would like to switch off my headlight low beam as described above (for off-road use only). Is there any problem with battery over-charging or any other electrical disadvantage?? From what I have read here, the electrical system is well balanced and I do not want to create a problem by not running the headlight. BTW, I joined the "old forum" in 2006 and have been an occasional reader. Just bought the kick start kit from North Bay and will attempt the install with the help of the info posted here. Thanks folks.
1 - 14 of 14 Posts
