Ricochet Skid Plate Sound Dampener (my solution, tested and works 98% of resonant sounds stopped)
Required:
1) 2" x 1-1/2" x 3/16" medium hardness rubber pad or equivalent,
I used rubber mounting pad from Samsung Solid State Drive (SSD) mounting kit.
2) .357" punch
3) Hammer
4) Sharp knife
5) Ruler
6) Pencil or marker
Instructions:
Take rubber pad above and trace out two 1" x 1" squares
Cut out squares using sharp knife or scissors and retrieve your punch
Using hammer and a piece of wood punch center holes in rubber pads
Mount each rubber pad between Ricochet plate and left/right motor mount brackets
That's all folks! No more high pitched annoying sounds coming off your new skid plate...
(not sure how I attached the last two thumbnails but the editor won't let me get rid of them LOL)
My Ricochet showed up yesterday, and I liked the idea of dampening any odd noises it may bring. No idea if it sounds any different than without them, but I certainly didn't notice any high pitched noise.
Hockey puck and a hole saw:
Drilled out to bolt size:
Chucked in the slicemaster 5000:
Go go gadget rubber things:
What, no grommet like sleeve to further isolate bolt threads from Ricochet plate? :p
Actually both the above posts are good innovations
Nice set of equipment you've got to work with. I do like my punch better though lol
It's not as fancy as it looks. Small benchtop drill press from whichever box store chain sells Delta, and a little baby Atlas/Craftsman 6" lathe from craigslist.
Well, since you mentioned it... You can see a bit of a protruding inside lip left by the parting tool in the shot below (right side of long bolt, inside of bracket). I oriented all the discs so that the protrusions all faced inward to the skidplate itself for that very reason. So not a full sleeve, but the threads are at least partially isolated.
Sweet! Think you could do something for the high pitch noise of a Speed Triple? :rolleyes: triumph speed triple.jpeg
I'll sure as hell try, but I will need a test unit here for extended and very thorough evaluation and prototyping.
That thing has a similar lighting setup to what I'm working on for the TW.
Designed around a TruckLite 7" LED headlight and their 4" round foglight with yellow Lamin-X on it, same as I use on the cars that take the 7" rounds.
