Yes, rocker arm ratios affect the measurements.
The link does'nt work. Can you convert it to a pdf and post it? Or take a photo and post a jpeg ?
if you're measuring direct at the cam then yes. I think and hope so there aren't different rockers - think that would require different point of pivot of rocker in the head, thus slightly different head - I doubt that.
I checked and XT225/TTR225/YFM250 (years 1999-2007) all have the same # - 29U-12151-00-00 - and price for rockers. TW200 and 125 ( checked years 1999 and 2008) have this # - 36X-12151-00-00 and different price than the 29U ones.
This is how I measured it all.
I exported it to PDFs, now it should work.
we can calculate rocker ratio from this, though I currently have only one cam, so no averaging possible right now and only caliper measurements.
Max IN valve lift: 8,13mm; max EX valve lift: 8,21mm
both IN and EX lobes measure 36,7mm at max and base cam circle is 30,25. this means lift at cam is 6,45mm
8,21/6,45=1,273
1,273mm of movement at valve for every one mm of cam lift. is that right?
now I realized I could borrow genuine tw125 head and compare it to my clone yfm head.
