I'm a bit confused after reading some different threads, so I'll ask. The clutch on my 2012 is quite simply the worst clutch I've had on, well... anything. It's jerky, it seems like it engages in a different place at times, and it almost feels like an on/off switch, rather than a clutch (the spring is installed correctly). I could try a different lube I guess, I've been using a teflon lube, which I like very well for most things. Now I'm wondering if I should try a Motion Pro cable but will it do anything? Will it make a difference that's worth the cost of the cable? I'll basically be replacing a cable that's just a few months old on a bike that has less than 1000 miles on it.
Should I quit obsessing about this or is it possible to make it smoother? Would a stronger or double spring be dumb idea?
