I just found a 2001 TW with 14XXX miles on it that has been sitting for a couple of years. When I took the carb off the bike I was surprised that it was clean inside. Regardless, I cleaned all the jets and blew them out with compressed air, replaced the bowl gasket and pilot screw because the small o-ring at the top of it was destroyed as well as the rubber stopper/cap. So I put it back together and it still will only run with the Choke in the on position. So I tried adjusting the pilot screw. I screwed it all the way in and then backed it out to 2.5 turns. I kept trying it until I was probably 5 turns out before it would barely idle without the choke. Then at that point I tried giving it some throttle and it would die.
Any suggestions? I also tried adjusting the throttle stop adjuster cable but it seemed like I was just trading one problem for another.
I have a TK Carb with a #120 Main Jet and a #31 pilot jet. Everything else is stock.
Well, my factory new 2015s with TK and 31 pilots would die if given throttle off choke, even after a lengthy warm up. I had to drive a mile or so on choke after a lengthy warm up before I could turn off the choke and ride without the engine dying. Even with the idle mixture screws backed out a few turns. They would still take a few additional miles before they really cleaned up and ran reasonably well. With the stock screw adjustment they would never run right.
A 34 pilot fixed that right up. With the 31 your may find you have to ride for a bit on choke before you can turn it off without dying.
Side note, isn't a 120 a very small main jet for the TK? I think the stocker is at least a few sized bigger.
BTW I am not sure what model year the carbs and or jet sizes were changed, but I know at some point they were - I think 2001. I think I read the newest TW now have a third generation carb setup.
Edit, Here we go: http://tw200forum.com/forum/technical-write-ups/14969-tw-carb-jet-part-s.html
I went to the dealer yesterday to look for a #34 main jet and or course, they didn't have one. They did however have a #38 so I decided to give it a try and it worked. Now it runs without the choke on and I set the air fuel mixture screw to 2 turns. Thank You both for your advice.
Wp that shows you that the stock pilot jet was plugged. You may want to order a stock one and maybe a 34 pilot also to use for different jetting situations. I have three sizes of main jets too including the stock size for mine so I can adjust if needed.
EDIT: After thinking about your bike can you check your mfg date or show a pic of your carb. Your bike is at the cross over date between two carbs. If you have an early carb the stock pilot is a #40 and stock main jet is a #114. So if someone put in the wrong jets when cleaning before selling that could be what's up. 2001 and later #31 pilot and #126 are stock. So your jetting was non stock for both carbs.
Also my dealer didn't stock the jets. I called him by phone with the numbers from the tech list and then picked them up, no shipping charges.
That should be a pretty fat pilot. My hunch is that you probably don't need to be 2 turns out. Mine ran well with the 34 and out only 1 turn. I after a bit of didling and cold starts I ended up at 1 1/8 turn out. I still plan to verify that is the warm engine highest idle setting with an inductive tach in the next few weeks, but for now, starts and runs great.
Side note, both mine came from the factory at about 7/8 turn out with the 31 pilot.
