1 - 20 of 40 Posts
Brand new factory sealed bag with all mounting hardware Fits TW200 $85 plus actual postage
Payment by US Postal Money Order available at any US Post Office (Only US Postal no other types of bank checks or MO's please)
I have 2 of these available
Chase Bank "Quick Pay" also accepted
No paypal please
I think the Richochet skidplates we have is some of the best money I've spent. Those things are bombproof.
hey Fred...is there any clearance problem with that skidplate?? I recall someone mentioning something about the drain plug with an aftermarket plate.
I have them on all 5 TWs. No clearance problems at all.
There is an opening in the skidplate below the oil drain bolt. You can get a wrench in there no problem, just a shorter stroke if you will. The problem some folks have had in the past is when they strip the drain bolt head. At that point, you most likely need to remove the plate so you can use whatever method available to remove the damaged drain bolt head.
Under normal circumstances you won't need to remove the plate if you don't want too!
I remove drain plug with a 19mm socket on an extension so their is no clearance issue for me. Sometimes I remove shifter first, other times just hold shifter down while R&R-ing plug. Some of the draining oil does run down the skid plate making a mess so if you wish to have a pristine bike go ahead and remove the Ricochet first.
Discussion Starter #13
These skid plates can be dropped in 15 seconds and you can take 2 sips of coffee during that 15 seconds
Removal is actually easier than removing the seat
The hardest thing is finding your allen wrench set to remove 2 screws
I received the RICOCHET / MSR skid plate from PlacerLoad today. It was complete with all hardware, instructions and included a few bonus items - better than new!
The skid plate is HEAVY DUTY, the pictures here and in other places on the interwebs do not do this skid plate justice.
Thanks again!
Discussion Starter #15
They do act as a parabolic reflector amplifying engine sounds to the rider and that does take a little getting used to
Fred might be onto something adding a rubber "shock" in the mount might be worthwhile but the damn things are bullet proof (literally) lol
Rubber mounting it and then putting some "wetsuit" type material inside it does help; but it will always seem loud anyway.
1 - 20 of 40 Posts
