Just had to relate a learning experience for me. Some may recall another thread that asked who had had a blowout, talking about old tires and when to replace them. That thread stimulated me to buy new tires to replace the originals for my 2002 bike. The tread was good but they were 9 years + old and thus in need of replacement for safety reasons.
I had a slow leak in the front tire that had been there for at least 1 year. It never went flat/flat but over a week or 10 days it would drop from 18 psi to 10 or so. When we replaced the front tire and tube, I took the old front tube home for a backup and on careful examination found it had a cholla spine (cactus spine about 1" long) in the tube. It clearly sealed the hole pretty well but allowed a slow trickle leak from high to low pressures. Apparently it had pulled all the way through the tire and hence was primarily in the tube cavity. Lesson 1. Slow leaks usually represent something in your tire - they could stay the same or get worse. They never get better without slime or some other alchemy.
The back tire was a different story. I had never had a problem with air pressure drop in it and we had intended to change the tube anyway -- however, my MC shop guy messed up, ordered the wrong tube and so on new tire day we had no tube but the original to stick in the rear tire. No problem we think and buttoned the bike back up and I rode away. When I got home, I checked the pressure because my man always overinflates the tires based on his road bike experience. As I let some air out (down from 30 to 18 psi), I notice that there seemed to be air released from one of the spoke holes. I immediately assumed he had pinched the tube when inserting it, and it was more prone to leak at lower pressures than at higher ones (or maybe it was leaking slowly anyway, but I had not noticed till then). I called him and we scheduled a look at the tire when we had a chance to get a new tube. In the three days it took to get a new tube, the back tire went completely down, but would stay up for a few hours if I pumped it to 20 psi or so for a short ride, or to deliver the bike to the local shop. My guy swore he would not have pinched the tube in such a big tire (rear) and so I had probably run over a "something" on my way home. Possible but not likely in my mind.
When we finally broke into the new rear tire that was going flat we found nothing in the tire to indicate it was a puncture, and a puncture in the tube (not a pinch). On careful examination of the old tire (there was a big spine (probably mesquite or russian olive) in the tire that had stayed there (leaving a hole in the tube that we had switched to the new tire). We had not checked the old tube for holes (it had never leaked, even tho it had obviously been punctured by a mesquite spine still residing in the old tire.
Lesson 2 - After you ride on tires for 6000 miles or so, expect things to be in them whether they leak or not. Always check the inside of the tire if you have it off, and most especially praise the TW for having beefy tires that can tolerate things like cactus and mesquite spines without having to go flat immediately. I love my little fat tired bike and have even more respect for its foot ware than I had previously. Probably ride on and maybe even a bit of Slime would have solve either leak but not made my old tires any more resistant to age degradation.
Long story, but it might save someone some grief. Tom BTW I installed the original tires - I like them for the mixed style of riding I do around New Mexico. Tom
