Finally got some snow so I can perform some actual testing of the "sheet metal screw" idea (as tire studs) in the front tire. Wish I could report some reliable info, but the jury is still out. I have the SR244.
Tire only (no SM studs) aired down = marginal in virgin not ridden snow. If packed snow, not good at all.
With SM Studs = If packed snow, better than no studs, but still more movement than I'm comfortable with.
I ran out of screws and need to get more. I plan on placing more studs in.
I used to ice race and sheet metal screws work real good (front & rear) on bare ice but they don't add a heck of a lot in snow....maybe a little on hard packed.
Here's a pic of a real aggresive studded tire I saw at Justice brother's shop in LA.
This is the conclusion I'm coming too as well. I'm on the lookout for a small set of tire chains I could maybe use on the front tire, similar to mrgizmow's cable chains. For the type of riding I do in the winter, (off road), chains should work. Still want to fiddle with the sheet metal screws some more before I rule them in or out.
